Register | FAQ's | New Posts | Today's Posts | Extras |
» Dryer squeal like a stuck pig! |
![]() Model Number: Intellidry Brand: Maytag Age: 1 - 5 years
![]() When my dryer starts and at periods during running it squeals like a stuck pig. I have had the dryer rollers/cylinder assembly changed three times at my expense. Which causes it to quit for a while. Appliance repairman said these dryers are prone to do that, lucky me! I have the part to repair the dryer but where do I get instructions to do so? At this point I would never buy a Maytag appliance again. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Well, first of all the Maytag techs are not correct. Even if the dryer is prone to roller failure it should not do so three times in less than five years. Something else is going on here, which you need to find or you will just be making repairs constantly until the real problem manifests itself in a failure.
Please post your model number, and let's see what we have.
__________________
![]() Ok, here is the service manual which will explain how to fix your dryer.
http://www.servicematters.com/maytag...s/16023020.pdf Again, let me emphasize that when you take this apart you need to try to find out what is causing this, or else this will just be a regular procedure. Good luck and let us know what you find when you tear down the machine.
__________________
![]() Quote:
I have the same dryer and same noise problem but when i clicked on the link you sent for the manual, i got "page not found". Would you be so kind as to re-post the link to the manual for the Maytag dryer # SDE4606AYW ? THANK YOU |
![]() Here is another source for that manual
http://appliancejunk.com/forums/inde...t=13 32207726 You may have to join the site to download the manual but it is free and has lots of manuals for all appliance types.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
maytag gas dryer squeal | lotzahotsa | Dryer Repair | 0 | 01-01-2010 07:32 AM |
brake squeal | DLAWR | Washer Repair | 2 | 11-28-2009 07:00 AM |
motor squeal | talbot | Dryer Repair | 1 | 06-10-2009 09:46 AM |
Maytag Gas Dryer Squeal | outonalim | Dryer Repair | 1 | 02-18-2009 05:33 PM |
Squeal on final rinse | gregerr | Washer Repair | 0 | 12-18-2008 10:07 AM |
