| » Dryer won't heat |
Model Number: DJSR473ET3WW Brand: GE Age: 1 - 5 years
Dryer just stopped heating. No warning.
Well, first you need to check and make certain you are still getting 240 volts to the machine. Sometimes the breaker will partially trip and send enough power to operate the machine but not enough to cause the heating coils to come one.
If this is not the problem, and likely it is not, then you need to open up the machine and do a continuity test on the thermostats and safety fuses. Be sure and disconnect the power to the machine when doing this. If you find this is the problem, take the opportunity to also thoroughly clean out the venting system. Restricted air flow is the single largest cause for a thermostat/fuse failure. Good luck, and post the results. If you do not find the problem let us know also.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
