Discuss
Roper Dryer: Low Heat since moving...
 in
Dryer Repair
When I moved, I noticed that the dryer duct outlet in my new home was smaller than at my previous
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Dryer: Low Heat since moving...
  #1 (permalink)
Old 05-05-2009, 11:50 AM
Junior Member
dbolan is on a distinguished road
Default Roper Dryer: Low Heat since moving...
Brand: Roper   Age: 1 - 5 years
When I moved, I noticed that the dryer duct outlet in my new home was smaller than at my previous residence.
The outlet on the dryer is about 4-1/2-5" and was such at the old place.
However, the receptacle at the new place is about 3 to 3-1/2" in diameter. Since the move, it takes 2 cycles to dry a load.
I was curious if the reduction in the diameter of the exit plumbing could cause this? Maybe I need to install a larger ducting outlet??
Ads By Google
  #2 (permalink)
Old 05-05-2009, 12:28 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Yes it could cause this problem.
A 4 inch pipe is actually 75% larger in cross sectional area than a 3 inch, so there is a big difference in the amount of air it can carry.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide pro
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
roper dryer no heat sgrimes9 Dryer Repair 7 01-18-2012 12:37 PM
Roper Gas Dryer, No Heat, All else ok teemade Dryer Repair 0 09-22-2009 06:20 PM
Dryer won't heat and timer knob not moving Calicia Dryer Repair 4 03-30-2009 05:12 PM
electric dryer won't heat and timer not moving chefbeav Dryer Repair 1 12-27-2007 02:18 PM
