Dryer is only heating for the initial heat cycle. The ignitor glows as it should on the following cycles but no flame. I just replaced the flame sensor as it had a broken tab. Checked the Thermostat, got 00.4 ohm reading at 200 setting, that is correct for a good part right? Are my coils bad? How do I check those? One has two connections, the other has three? I do not see any other obvious sensors to check. Is there some hidden somewhere? Thanks in advance for the help.
Two connection coil reads 1229 Three connection reads 1371 left and middle 560 left and right 1930 middle and right
edit: The more I dig and read the more I realized I missed. Got the thermostat on the exhaust. Looks like two stacked on each other. The lower portion reads 00.4 ohms. I get no reading for the top portion. I am going to assume this is my bad part. You experts agree?
