my whirlpool 3 cycle dryer would run but not heat up. i checked the thermal fuse and heating element for continunity and both are ok. i cleaned out the ver and put itall back together and now it wont run at all. any suggestions
Here are your parts Replacement parts for WHIRLPOOL LER3624EQ0 LAUNDRY DRYERS | AppliancePartsPros.comSee the attachment for the tech sheet. If it was dead as right after you did your reassemble then odds are something has come loose or you forgot to reconnect something. High on the list would be the door switch and the push-to-start switch. If it ran for a whole and then stopped it is probably the thermal fuse on the blower. If you cannot find it then start by checking the power. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
