| » kenmore ultra fabric care center |
Your model number is missing the first 3 digits.
It is these digits which specifies who actually made the unit. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!! The motor runs off of half the line (120 volts) while the heater requires the full 240 volts. If power is OK then check the heating coil and then the thermal cut-off for continuity.
__________________
| Display Modes | |
| Kenmore Ultra Fabric Care PLEASE HELP!!! | sagakontinues | Dryer Repair | 0 | 07-09-2010 04:58 PM |
| Kenmore Ultra Fabric Care Dryer (gas) won't spin | tdmbulk | Dryer Repair | 3 | 07-01-2010 02:23 PM |
| Kenmore Ultra Fabric Care | willing303 | Washer Repair | 1 | 07-13-2009 01:05 PM |
| Kenmore Ultra Fabric Care series 80 Clogged Filter | CrystalRansom | Washer Repair | 0 | 03-02-2009 06:34 PM |
| Kenmore Ultra Fabric Care Dryer | anniesmomrocks | Dryer Repair | 3 | 02-16-2009 01:06 PM |
