Discuss
DRYER doesn't heat, it runs fine
 in
Dryer Repair
DRYER doesn't heat, it runs fine Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » DRYER doesn't heat, it runs fine
  #1 (permalink)
Old 05-03-2009, 01:02 PM
Junior Member
luzma is on a distinguished road
Default DRYER doesn't heat, it runs fine
Brand: Roper   Age: 5 - 10 years
Ads By Google
  #2 (permalink)
Old 05-03-2009, 04:59 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well, without a model number I am assuming you have the basic dryer. Unplug the machine, take off the back and test each fuse and thermostat for continuity. If all check out, test the heating element for continuity to the cabinet. If it has continuity to the cabinet it is broken and grounded out. If it is not grounded, test the heating element for ohms.
Most importantly, after you find the problem be sure and clean out the dryer, particular the venting system. Make sure there is absolutely no obstruction for air to leave the dryer.
Good luck and post what you find.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer will not heat but runs fine! dcrenlop Dryer Repair 2 07-21-2009 10:29 AM
MW runs fine but does not heat ff36ike Microwave Repair 1 01-08-2009 01:42 PM
Dryer runs fine but no heat grigabuoy Dryer Repair 2 06-04-2008 02:47 AM
Inglis Dryer no heat, otherwise runs fine Islandbob Dryer Repair 2 05-27-2008 07:19 PM
Inglis Dryer no heat, otherwise runs fine Islandbob Dryer Repair 2 05-23-2008 10:33 AM
