dinol56@yahoo.com
#1 Posted : Sunday, May 3, 2009 10:27:22 AM(UTC)
dinol56@yahoo.com
it runs fine just no more heat
sidfink43
#2 Posted : Sunday, May 3, 2009 4:08:01 PM(UTC)
sidfink43
Ok, you need to check the thermal cut offs, thermal fuses and thermostats for continuity. If one does not have continuity, replace it and you should be fine.
If all check out, post and let us know and we will go from there.
Good luck
dinol56@yahoo.com
#3 Posted : Tuesday, May 5, 2009 10:32:12 AM(UTC)
dinol56@yahoo.com
Good luck
where would I find the thermal cut offs, thermal fuses and the thermostats. and how do I go about checking to see if it has continuity
dinol56@yahoo.com
#4 Posted : Tuesday, May 5, 2009 10:37:36 AM(UTC)
dinol56@yahoo.com
where would I go on line to get a diagram of where everything is in my dryer
sidfink43
#5 Posted : Tuesday, May 5, 2009 3:15:23 PM(UTC)
sidfink43
Ok, well obviously you are new to this but that is good. If your problem is a thermal fuse or thermostat, the diagnosis is easy, the parts are inexpensive and if you succeed you will have saved well over $100 in service call and parts.
First of all, always have the dryer unplugged when you work on it. There are no exceptions to this rule.
Next, here is a site that has good explanations of dryer, how they work and how to work on them.
http://www.applianceaid.com/dryers.html
As far as continuity checks are concerned, read the info on the above site, but also look on the first dryer page near the top on this forum and you will see a link to continuity testing.
You will need an electrical meter. A good one can be had from any hardware store, Sears, Radio Shack etc for about $15 to 20. It is a good thing to have around the house. Learning how to use it can save you big bucks down the road.
The first thing you should test for it to make sure you are getting 240 volts to the dryer. Sometimes the breaker will partly trip and if you are getting 120 the dryer will run but not heat.
You might want to get a friend, acquaintance, etc who is familiar with electrical testing to help you.
I think your dryer is accessible by taking off the rear panel. This will expose the fuses, thermostats etc. Start with the thermal fuse, it is the long, white one and most likely the culprit.
If you find a fuse or thermostat is blown, and even if you don't take the opportunity to thoroughly clean the dryer insides, particularly the venting system. The large majority of problems are cause by partially blocked venting system, and it is dangerous to operate the dryer this way.
You can access parts diagrams by using your model number, without the hypen on the parts section of this site. The nice folks at AppliancePartsPro will help you get parts, they have great prices and ship immediately, and no I do not work for them.
Good luck, and let us know how it turns out.
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
Dryer does not heat, but runs, all parts seem to be good (Dryer Repair)
by discgolfdoug 10/14/2012 8:01:10 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Kenmore H3 Dryer does not heat (Dryer Repair)
by tim75 8/7/2012 10:12:46 AM(UTC)
by tomromeyn7 6/3/2012 2:57:52 PM(UTC)
Electric dryer does not heat. (Dryer Repair)
by Wtucker 4/19/2012 11:10:26 AM(UTC)
by thabersaat 2/27/2012 11:10:06 AM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by lingo622 9/22/2011 12:03:52 PM(UTC)
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 7/28/2011 10:55:43 AM(UTC)
by nwiccauto 6/16/2011 10:02:50 AM(UTC)
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 5/19/2011 2:34:34 PM(UTC)
