I just replaced the thermostat assembly, 2 parts (6931EL3003D, high heat thermostat and 6931EL3001E, thermostat assembly). There was no way to determine which connector the red and white wires were to go to. Is it possible to install them with the wires reversed...or does it matter?
[COLOR="DarkRed"]Is it possible to install them with the wires reversed...or does it matter?[/COLOR] Looks like both the devices (hi-limit and thermostat) are 2 connector devices so it does not matter which wire goes where as long as the correct wires are used for each device. |
THIS FORUM IS DEAD!!!!!!! |
