Discuss
Kenmore Electric Dryer cuts off after running 2/3 minutes
 in
Dryer Repair
MY Kenmore electric dryer starts and runs for 2 or 3 minutes and then shuts off. When I try to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Electric Dryer cuts off after running 2/3 minutes
  #1 (permalink)
Old 10-14-2011, 10:21 AM
Junior Member
Robert Ferrell is on a distinguished road
Default Kenmore Electric Dryer cuts off after running 2/3 minutes
Model Number: 11061802000   Brand: Kenmore   Age: 1 - 5 years
MY Kenmore electric dryer starts and runs for 2 or 3 minutes and then shuts off. When I try to restart nothing happens. If I wait for 5 or 10 minutes, the dryer will start again and run 2 or 3 minutes and shut off.
I replaced the timer but no change.
Thanks,
Robert
Ads By Google
Related Models
Kenmore 11062032100 ELECTRIC DRYER
Kenmore 11062036100 ELECTRIC DRYER
Kenmore 11062042100 DRYER
Kenmore 11062052100 DRYER
Kenmore 11062054100 DRYER
Kenmore 11062056100 DRYER
Kenmore 11062062100 DRYER
Kenmore 11062062101 ELECTRIC DRYER
Kenmore 11062062102 ELECTRIC DRYER
Kenmore 11062064100 DRYER
Kenmore 11062064101 ELECTRIC DRYER
Kenmore 11062064102 ELECTRIC DRYER
Kenmore 11062066100 DRYER
Kenmore 11062066101 ELECTRIC DRYER
Kenmore 11062066102 ELECTRIC DRYER
Kenmore 1106207400 KENMORE GAS DRYER
Kenmore 1106207401 KENMORE GAS DRYER
Kenmore 1106207420 KENMORE GAS DRYER
Kenmore 1106207421 KENMORE GAS DRYER
Kenmore 1106207430 KENMORE GAS DRYER
Kenmore 1106207431 KENMORE GAS DRYER
Kenmore 1106207432 KENMORE GAS DRYER
Kenmore 1106207433 KENMORE GAS DRYER
Kenmore 1106207500 KENMORE GAS DRYER
Kenmore 1106207501 KENMORE GAS DRYER
Kenmore 1106207502 KENMORE GAS DRYER
Kenmore 1106207511 KENMORE GAS DRYER
Kenmore 1106207600 KENMORE GAS DRYER
Kenmore 1106207601 KENMORE GAS DRYER
Kenmore 1106207700 KENMORE GAS DRYER
Kenmore 1106207701 KENMORE GAS DRYER
Kenmore 1106207702 KENMORE GAS DRYER
Kenmore 11063012100 ELECTRIC DRYER
Kenmore 11063012101 DRYER
Kenmore 11063012102 ELECTRIC DRYER
Kenmore 11063014100 ELECTRIC DRYER
Kenmore 11063014101 DRYER
Kenmore 11063014102 ELECTRIC DRYER
Kenmore 11063022100 DRYER
Kenmore 11063022101 ELECTRIC DRYER
Kenmore 11063022102 ELECTRIC DRYER
Kenmore 11063024100 DRYER
Kenmore 11063024101 ELECTRIC DRYER
Kenmore 11063024102 ELECTRIC DRYER
Kenmore 11063032100 ELECTRIC DRYER
Kenmore 11063032101 ELECTRIC DRYER
Kenmore 11063032102 ELECTRIC DRYER
Kenmore 11063034100 ELECTRIC DRYER
Kenmore 11063034101 ELECTRIC DRYER
Kenmore 11063034102 ELECTRIC DRYER
Kenmore 11063036100 ELECTRIC DRYER
Kenmore 11063036101 ELECTRIC DRYER
Kenmore 11063036102 ELECTRIC DRYER
Kenmore 11063042100 ELECTRIC DRYER
Kenmore 11063042101 DRYER
Kenmore 11063042102 ELECTRIC DRYER
Kenmore 11063046100 ELECTRIC DRYER
Kenmore 11063046101 DRYER
Kenmore 11063046102 ELECTRIC DRYER
Kenmore 11063052100 DRYER
Kenmore 11063052101 DRYER
Kenmore 11063052102 ELECTRIC DRYER
Kenmore 11063062100 DRYER
Kenmore 11063062101 ELECTRIC DRYER
Kenmore 11063062102 ELECTRIC DRYER
Kenmore 11063064100 DRYER
Kenmore 11063064101 ELECTRIC DRYER
Kenmore 11063064102 ELECTRIC DRYER
Kenmore 11063066100 DRYER
Kenmore 11063066101 ELECTRIC DRYER
Kenmore 11063066102 ELECTRIC DRYER
Kenmore 1106307400 KENMORE GAS DRYER
Kenmore 1106307401 KENMORE GAS DRYER
Kenmore 1106307402 KENMORE GAS DRYER
Kenmore 1106307500 KENMORE GAS DRYER
Kenmore 1106307501 KENMORE GAS DRYER
Kenmore 1106307502 KENMORE GAS DRYER
Kenmore 1106307504 KENMORE GAS DRYER
Kenmore 1106307600 KENMORE GAS DRYER
Kenmore 1106307601 KENMORE GAS DRYER
Kenmore 1106307602 KENMORE GAS DRYER
Kenmore 1106307603 KENMORE GAS DRYER
Kenmore 1106407400 KENMORE GAS DRYER
Kenmore 1106407401 GAS DRYER
Kenmore 1106407500 KENMORE GAS DRYER
Kenmore 1106407501 KENMORE GAS DRYER
Kenmore 1106407502 KENMORE GAS DRYER
Kenmore 1106407540 KENMORE GAS DRYER
Kenmore 1106407700 KENMORE GAS DRYER
Kenmore 1106407701 KENMORE GAS DRYER
Kenmore 1106407702 KENMORE GAS DRYER
Kenmore 1106407740 KENMORE GAS DRYER
Kenmore 1106407741 KENMORE GAS DRYER-NOVEMBER, 1964
Kenmore 1106407800 KENMORE GAS DRYER
Kenmore 1106407801 KENMORE GAS DRYER
Kenmore 1106407840 KENMORE GAS DRYER
Kenmore 1106407841 KENMORE GAS DRYER
Kenmore 1106407900 KENMORE GAS DRYER
Kenmore 1106407901 KENMORE GAS DRYER
Kenmore 1106407902 KENMORE GAS DRYER
Kenmore 1106407920 KENMORE GAS DRYER
Kenmore 1106407922 KENMORE GAS DRYER
Kenmore 1106407930 KENMORE GAS DRYER
Kenmore 1106407931 KENMORE GAS DRYER
Kenmore 11064082200 ELECTRIC DRYER
Kenmore 11064082201 ELECTRIC DRYER
Kenmore 1106408400 KENMORE ELECTRIC DRYER
Kenmore 1106408401 KENMORE ELECTRIC DRYER
Kenmore 11064084200 ELECTRIC DRYER
Kenmore 11064084201 ELECTRIC DRYER
Kenmore 1106408500 KENMORE ELECTRIC DRYER
Kenmore 1106408501 KENMORE ELECTRIC DRYER
Kenmore 1106408540 KENMORE ELECTRIC DRYER
Kenmore 11064086200 ELECTRIC DRYER
Kenmore 11064086201 ELECTRIC DRYER
Kenmore 1106408700 KENMORE ELECTRIC DRYER
Kenmore 1106408701 KENMORE ELECTRIC DRYER
Kenmore 1106408740 KENMORE ELECTRIC DRYER
Kenmore 1106408741 KENMORE ELECTRIC DRYER
Kenmore 1106408800 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 10-15-2011, 03:56 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for KENMORE 11061802000 | AppliancePartsPros.com
Sounds like a motor problem since you have to wait to restart it.
What is happening is the motor is overheating, it's internal thermal protect trips and then you have to wait for it to cool down and reset before it will start again.
There can be a number of causes of this.
1. Too much drag on the motor.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this) but usually you will also hear this. Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
Check the drum seals, rear and front supports, motor bearings etc.
2.The motor's centrifugal switch is not activating.
The motor has 2 centrifugal switches. One is for the heater but the other is for the motor windings. It switches out the start winding which if left in circuit will cause the motor to overheat. Often it is just a lot of lint/dust in the motor causing problems.
3. Hot air is being blown back onto the motor.
Many units have a seal between the blower and the motor. This can be checked by running an air only cycle. If it runs OK I would check for this. Also might be a dirty vent system forcing hot air back onto the motor.
4. The motor is on it's last legs and needs replacing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer cuts off after running for about 2 min jim5sexton Dryer Repair 1 03-03-2011 02:34 AM
Whirlpool Dryer Stops After Running 5 Minutes beverlyjean Washer Repair 4 05-18-2009 04:42 PM
dryer cuts off after 10 minutes but will start 30tredog Dryer Repair 2 10-01-2008 06:08 PM
dryer cuts off after 10 minutes but will start 30tredog Dryer Repair 1 09-30-2008 05:04 PM
kenmore dryer heat cuts out after a few minutes stumpedagain Dryer Repair 0 08-22-2008 07:06 PM
