Discuss
kenmore dryer with no heat
 in
Dryer Repair
I have a kenmore 70 series dryer, the dryer cycles fine in all drying modes but it is cold air.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore dryer with no heat
  #1 (permalink)
Old 12-07-2007, 05:00 PM
flashme12 flashme12 is offline
Junior Member
flashme12 is on a distinguished road
Default kenmore dryer with no heat
Model Number: 11068712894   Brand: Kenmore   Age: 1 - 5 years
I have a kenmore 70 series dryer, the dryer cycles fine in all drying modes but it is cold air. I thought at that point I would put in new elements, it still doesn't heat. I checked the resistor and it had the same resistace as the new one. The high limit switch has continuity acroos it. The fuse link in the lent tube has continuity across it, the running heat switch has four wires on it, the power wires have continuity acrooss it, the purple wires in the center do not have continuity. There is one more heater at the top of the element cage and it has continuity as well. Is there a thermo heater in the motor that could cause it, or the four wire thermo switch. Thank you in advance for your help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-07-2007, 05:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check if 240V is coming to the dryer.
The motor needs just 120V but the heat element needs 240V. Check the circuit breakers and the power outlet.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-07-2007, 09:34 PM
Junior Member
Default
I have 240volt coming into the dryer, just not to the element after it goes through the motor
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Dryer Don't Heat paulgtwo Dryer Repair 1 11-27-2007 06:25 PM
Kenmore Gas Dryer Does Not Heat leobutera Dryer Repair 0 11-25-2007 12:07 PM
kenmore dryer-no heat gvalen Dryer Repair 2 11-15-2007 06:58 PM
Kenmore gas dryer don't heat tinatinagirl5 Dryer Repair 0 11-09-2007 08:56 AM
Intermittant heat from Kenmore Gas Dryer theoutcaste Dryer Repair 3 09-17-2007 09:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
