Discuss
Whirlpool Thin Twin, dryer thermal cutoff failed twice
 in
Dryer Repair
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Thin Twin, dryer thermal cutoff failed twice
  #1 (permalink)
Old 10-12-2011, 10:17 PM
Junior Member
NorseGod is on a distinguished road
Default Whirlpool Thin Twin, dryer thermal cutoff failed twice
Model Number: LTE6234DQ2   Brand: Whirlpool   Age: 5 - 10 years
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the Thermal cut-off switch was open. Purchased Dryer thermal cut-off kit and replaced as per instructions. Heat has returned and dryer works as designed.
A month goes by and dryer has no heat again. Check parts from the following diagram: AppliancePartsPros.com LTE6234DQ2
Part number: AP3094244
Dryer thermal cut-off: open (again)
Part number: AP2973862
Dryer high-limit thermostat: closed
Part number: AP2946932
Cutoff - tml: closed
Part number: AP3131939
Dryer cycling thermostat: closed
Part number: AP3134638
Heating element: closed, reads ~12 ohms
Checked both leads of coil to frame, all open
Before I go and replace this same part again, what else should I check? What other steps are necessary to diagnose the original cause of this failure?
Checked vent hose: clear of debris
Ads By Google
Related Models
Whirlpool LTE6234DQ2
Whirlpool LTE6234DQ3 Washer/dryer Laundry System
Whirlpool LTE6234DQ4 Washer/dryer Laundry System
Whirlpool LTE6234DQ5 Washer/dryer Laundry System
Whirlpool LTE6234DQ6 Washer/dryer Laundry System
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
  #2 (permalink)
Old 10-13-2011, 03:40 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Sounds like the coil is OK but I would double check it. Also take a look at the inside for any sign that it has touched the case when hot. This is unlikely as it usually welds itself to the case but it can happen.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
  #3 (permalink)
Old 10-13-2011, 05:11 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
If the vent to the outside is good, it is very possible that the cycling thermostat is the issue, because, the temp could be getting to hot, and blowing the thermal cut-of. As a serviceman I have been replacing the cycling thermostat when I have a thermal cut-of go out, because I have gone back to that customers house, in a few days, only to change the cycling thermostat, and it do it. Tom ********************************************
  #4 (permalink)
Old 10-23-2011, 03:01 PM
Junior Member
Default
denman: had a look at all your issues listed, looks to be ok.
Popped out the cycling thermostat and it appears to be working fine, checked by putting it in the oven to heat and it opened, then closed again when cooled. The one thing though, there are another set of wires on this thermostat, purple ones. On the wiring diagram this appear to be the thermostat heater, and it was open both room temp and hot. Could this be the original source of the failure?
To re-iterate, this unit has had a thermal fuse blow twice now. The hi-limit thermostat was replaced after the first failure. Could a failed thermostat heater within the cycling thermostat be the cause of this issue?
Thank you all for your replies!
  #5 (permalink)
Old 10-23-2011, 04:10 PM
Senior Expert
APP Volunteer
Default
In case you do not have the same one see the attachment for the wiring diagram.
It should not. If you look at the cycle chart the heater is off in high heat selections.
It does need replacing and who knows maybe it is not opening at the correct temperature.
I cannot think of anything else because all other possible causes check out OK.
__________________
  #6 (permalink)
Old 05-29-2012, 06:22 PM
Junior Member
Opie1514 is on a distinguished road
Default Same problem-Whirlpool Thin Twin, dryer thermal cutoff failed twice Reply to Thread
I am having the same problem a you had. I suspect the "thermostat heater" has gone bad, as my unit runs at high heat no matter the selector setting (fairly certain that selector is operating correctly, as the ohms increase as I turn dial to increase heat amount.
Can you tell me what you found to be the fix, as I hate to keep guessing and replacing expensive parts.
Thanks in advance.
Respects,
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool thin twin dryer belt instulation Dryermang Dryer Repair 2 07-01-2011 09:03 PM
Whirlpool thin twin dryer doesn't always start nzdw22 Dryer Repair 1 06-28-2011 04:27 AM
Whirlpool Thin Twin dryer thermal fuse blown pdinnen Dryer Repair 3 01-12-2011 07:34 AM
Whirlpool thin twin stackable washer and dryer numisman1@yahoo.com Dryer Repair 2 12-14-2009 08:21 PM
Whirlpool Thin Twin dryer will not heat bolingmike Dryer Repair 0 07-29-2008 01:42 PM
