dryer not heating
replaced ignitor,coils and flame sensor,and still no heat please help:)
Hi
Open it up again and test all of the thermal fuses and thermostats for continuity using a meter. You will probably find one with an open circuit, and if you do replace it. If not, post the results and let's see what else it might be. |
dryer fixed wife happy
thank you for your answers changed thermal fuse and dryer cycling thermostat it worked:) :) :)
Great, and thanks for updating us.
| All times are GMT -7. The time now is 08:44 AM. |
