Discuss
Dryer only heats for short periods of time, if at all.
 in
Dryer Repair
My gas dryer is not heating staying lit long enough? I had the back off and could see it will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer only heats for short periods of time, if at all.
  #1 (permalink)
Old 04-30-2009, 08:08 PM
Junior Member
fred2117 is on a distinguished road
Default Dryer only heats for short periods of time, if at all.
Brand: Estate   Age: 5 - 10 years
My gas dryer is not heating staying lit long enough? I had the back off and could see it will ignite for maybe a few mins. It does'nt light right away just whenever? Is this the coils or what
  #2 (permalink)
Old 04-30-2009, 09:32 PM
TechnicianBrian's Avatar
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Most likely your coils need to be replaced as they have difficulty holding the valves open as they age. The usual symptom is ignition at the very beginning of a cycle, then nothing until the dryer is shut off and allowed to cool. If this is what you are experiencing, then the coils should do the trick.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 05-01-2009, 05:33 AM
Junior Member
Default
From what I've seen is it does'nt always light up right away. It came on after a few mins, then did the same thing after a while.
  #4 (permalink)
Old 05-01-2009, 07:20 AM
Senior Expert
APP Volunteer
Default
You could be dealing with a gas problem, but odds have it that it is the coils (AP2150379) causing the problem. Given the age of your dryer, if they have never been changed, I would start there before looking at other items in the burner assembly.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer heats for short time shellbutton Dryer Repair 4 01-01-2010 08:45 AM
Elec Dryer Stops after short time shews01 Dryer Repair 1 03-19-2009 03:25 AM
dryer heats but runs for a short time suckleh0nny Dryer Repair 8 11-10-2008 08:42 PM
gas dryer only heats up for short periods gregn Dryer Repair 0 08-01-2008 03:27 PM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 03:48 AM
