| » Estate Dryer -Shocking Currents |
Model Number: EED4300TQ Brand: Estate Age: 1 - 5 years
Hi, I have the above dryer which worked fine until we moved. We had to change the cord, from a 4 prong to a 3 prong to match the plug on the wall. I opened the door to the dryer to put clothes into it and felt a "tingle." Unsure if the dryer works, did not turn it on, after that encounter.
Please help! Thanks, Cheri Byrd Ads By Google Related Models |
You probably have 115 volts wired to the frame of the dryer! The middle wire of the power cord goes to the middle connection at the back of the dryer, the other two wires go to the the outer terminals. Also, make sure the frame of the dryer is electrically connected to the middle terminal. Also. make sure the power ground wire from the outside power cable is connected to the cold water pipe in the basement.
__________________
This may also help
http://www.applianceaid.com/general.html#3to4 See "Changing from 3 to 4 wire hookup on a electric dryer" at the bottom of the page.
__________________
| Display Modes | |
| estate gas dryer | tmbrinkworth | Dryer Repair | 0 | 10-16-2009 05:40 PM |
| Estate Gas Dryer LP gas | patcalvo | Dryer Repair | 0 | 10-10-2009 10:54 AM |
| Estate Dryer | fred2117 | Dryer Repair | 1 | 12-09-2008 03:16 AM |
| estate dryer | tmohler | Dryer Repair | 2 | 10-29-2008 05:53 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
