Discuss
Dryer won't start.
 in
Dryer Repair
I have recently (within the past year) replaced the main control switch as well as 2 other idems not related
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start.
  #1 (permalink)
Old 04-30-2009, 01:26 PM
Junior Member
Rick L. Gardner is on a distinguished road
Default Dryer won't start.
Model Number: LDG313   Brand: Maytag   Age: More than 10 years
I have recently (within the past year) replaced the main control switch as well as 2 other idems not related to the dryer not running and am unsure of why it will not start. Ofcourse I have checked the obvious power cord and breaker. Any suggestions ??
Ads By Google
Related Models
Maytag LDG313 Dryer - Gas
Maytag LDG313D Dryer - Gas
Maytag LDG31CA Dryer - Gas
Maytag LDG31CM Dryer - Gas
Maytag LDG31CT Dryer - Gas
Maytag LDG32CA Dryer - Gas
Maytag LDG32CM Dryer - Gas
Maytag LDG32CT Dryer - Gas
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA Dryer - Gas
Maytag LDG33CM Dryer - Gas
Maytag LDG34CD Dryer - Gas
Maytag LDG34CQ Dryer - Gas
Maytag LDG382 Dryer - Gas
Maytag LDG4000 Dryer - Gas
Maytag LDG4000AAL Dryer - Gas
Maytag LDG4000AAW Dryer - Gas
Maytag LDG4000ABL Dryer - Gas
Maytag LDG4000ABW Dryer - Gas
Maytag LDG407 Dryer - Gas
Maytag LDG408 Dryer - Gas
Maytag LDG409 Dryer - Gas
Maytag LDG410 Dryer - Gas
Maytag LDG412 Dryer - Gas
Maytag LDG412D Dryer - Gas
Maytag LDG482 Dryer - Gas
Maytag LDG482D Dryer - Gas
Maytag LDG490 Dryer - Gas
Maytag LDG490D Dryer - Gas
Maytag LDG4910 Dryer - Gas
Maytag LDG4910AAL Dryer - Gas
Maytag LDG4910AAW Dryer - Gas
Maytag LDG4914AAE Dryer - Gas
Maytag LDG4914AAL Dryer - Gas
Maytag LDG4914AAM Dryer - Gas
Maytag LDG4916AAE Dryer - Gas
Maytag LDG4916AAM Dryer - Gas
Maytag LDG5004AAW Dryer - Gas
Maytag LDG5004ABW Dryer - Gas
Maytag LDG5005AAE Dryer - Gas
Maytag LDG5005ABE Dryer - Gas
Maytag LDG510 Dryer - Gas
Maytag LDG512 Dryer - Gas
Maytag LDG512D Dryer - Gas
Maytag LDG590 Dryer - Gas
Maytag LDG590D Dryer - Gas
Maytag LDG5910 Dryer - Gas
Maytag LDG5910AAL Dryer - Gas
Maytag LDG5910AAW Dryer - Gas
Maytag LDG5914AAE Dryer - Gas
Maytag LDG5914AAL Dryer - Gas
Maytag LDG5914AAM Dryer - Gas
Maytag LDG5916AAE Dryer - Gas
Maytag LDG5916AAM Dryer - Gas
Maytag LDG6004AAW Dryer - Gas
Maytag LDG606 Dryer - Gas
Maytag LDG608 Dryer - Gas
Maytag LDG610 Dryer - Gas
Maytag LDG612 Dryer - Gas
Maytag LDG612D Dryer - Gas
Maytag LDG6914AAE Dryer - Gas
Maytag LDG6914AAL Dryer - Gas
Maytag LDG6914AAM Dryer - Gas
Maytag LDG710 Dryer - Gas
Maytag LDG712 Dryer - Gas
Maytag LDG713 Dryer - Gas
Maytag LDG7304AAE Dryer - Gas
Maytag LDG7304AAL Dryer - Gas
Maytag LDG7304AAM Dryer - Gas
Maytag LDG7304ABE Dryer - Gas
Maytag LDG7304ABL Dryer - Gas
Maytag LDG7304ABM Dryer - Gas
Maytag LDG7304AGE Dryer - Gas
Maytag LDG7304AGL Dryer - Gas
Maytag LDG7304AGM Dryer - Gas
Maytag LDG7304EGE Dryer - Gas
Maytag LDG7304EGL Dryer - Gas
Maytag LDG7304EGM Dryer - Gas
Maytag LDG7314AAE Dryer - Gas
Maytag LDG7314AAL Dryer - Gas
Maytag LDG7314AAM Dryer - Gas
Maytag LDG7334AAE Dryer - Gas
Maytag LDG7334AAL Dryer - Gas
Maytag LDG7334AAM Dryer - Gas
Maytag LDG7400 Dryer - Gas
Maytag LDG7400AAL Dryer - Gas
Maytag LDG7400AAW Dryer - Gas
Maytag LDG7400ABL Dryer - Gas
Maytag LDG7400ABW Dryer - Gas
Maytag LDG7480AAL Dryer - Gas
Maytag LDG7480AAW Dryer - Gas
Maytag LDG7480ABL Dryer - Gas
Maytag LDG7480ABW Dryer - Gas
Maytag LDG7500 Dryer - Gas
Maytag LDG7500AAE Dryer - Gas
Maytag LDG7500AAL Dryer - Gas
Maytag LDG7500AAM Dryer - Gas
Maytag LDG7500AAW Dryer - Gas
Maytag LDG7500ABE Dryer - Gas
Maytag LDG7500ABL Dryer - Gas
Maytag LDG7500ABM Dryer - Gas
Maytag LDG7500ABW Dryer - Gas
Maytag LDG7600 Dryer - Gas
Maytag LDG7600AAG Dryer - Gas
Maytag LDG7600AAL Dryer - Gas
Maytag LDG7600AAW Dryer - Gas
Maytag LDG7600ABL Dryer - Gas
Maytag LDG7600ABW Dryer - Gas
Maytag LDG7600AGG Dryer - Gas
Maytag LDG7600AGL Dryer - Gas
Maytag LDG7600AGW Dryer - Gas
Maytag LDG7800 Dryer - Gas
Maytag LDG7800AAL Dryer - Gas
Maytag LDG7800AAW Dryer - Gas
Maytag LDG7800ABL Dryer - Gas
Maytag LDG7800ABW Dryer - Gas
Maytag LDG8000 Dryer - Gas
Maytag LDG8000AAL Dryer - Gas
Maytag LDG8000AAW Dryer - Gas
Maytag LDG8000ABL Dryer - Gas
  #2 (permalink)
Old 05-01-2009, 01:25 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Ok, always difficult to diagnose, but
Here are a couple of things
1. Check your thermostats for continuity
2. Check the wiring harness to the motor
3. Check the Motor Switch
4. Check the start Switch by opening up the console and jumping the wires on the start switch to see if that cause the dryer to start.
Good luck, and let us know if you find the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
dryer start button noise - dryer won't run brhodes58 Dryer Repair 6 03-14-2009 02:11 PM
