Discuss
no heat!!
 in
Dryer Repair
I've cleaned the duct work and still no heat. The thermal fuse seems to be located in front of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat!!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-06-2007, 08:12 PM
racefan racefan is offline
Junior Member
racefan is on a distinguished road
Angry no heat!!
Model Number: crer5700as1   Brand: Frigidaire   Age: 1 - 5 years
I've cleaned the duct work and still no heat. The thermal fuse seems to be located in front of the duct...how do you get to it to replace or to put a meter on it. If the heating element needs to be replaced, which panel do you take apart, top, back, they seem to be spot welded... thanks for your help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-07-2007, 08:16 AM
Junior Member
Default
please reply as soon as possible
  #3 (permalink)
Old 12-07-2007, 08:40 AM
Bigboss88 Bigboss88 is offline
Junior Member
Bigboss88 is on a distinguished road
Default
Go to: http://www3.sears.com/
Input your model number. Then select "DRY/CAB HEATER"
It would appear that you will have to remove the drum to access the element.
I believe that you have a broken element.
Thank You
  #4 (permalink)
Old 12-07-2007, 11:55 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
FIRST check to see if you have the right voltage going to the dryer,There should be 240 volt,s going to the dryer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
