Discuss
Dryer will run... forever?
 in
Dryer Repair
I have an Amanda ale866sbw electric dryer. I noticed the other day that even though the clothes are dry, the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will run... forever?
  #1 (permalink)
Old 04-29-2009, 10:36 PM
Junior Member
sentientred is on a distinguished road
Wink Dryer will run... forever?
Model Number: ale866sbw   Brand: Amana   Age: 5 - 10 years
I have an Amanda ale866sbw electric dryer. I noticed the other day that even though the clothes are dry, the dryer will just continue to run and run.
The dryer does get hot, does stop when the door is opened and does shut off properly if its on a timed cycle.
Bad moisture sensor? Could I be that lucky to have it be a $3 part?
Thanks in advance for any help you can provide!
Ads By Google
Related Models
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
  #2 (permalink)
Old 04-30-2009, 04:59 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for AMANA ALE866SBW | AppliancePartsPros.com
Have you tried cleaning your sensor Item 18 in the "Front bulkhead" section.
Basically it is two strips of wire, when the clothes are wet the dampness between the wires creates a circuit path and this tells the unit the clothes are still wet.
If dirt etc. gets between the wires the unit sees this as wet clothes and continues to run.
__________________
  #3 (permalink)
Old 04-30-2009, 05:45 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Also those Amana's are known to build up lint in the blower housing. You would have to take the front off to get to it. It is attached to the front frame of the dryer, and is held on by two 5/16s screws on each side. If mama uses dryer sheets, you can get a build up on the sensor. Clean in with alchohol, or nail polish remover. Also chech and make sure one of the wires did not vibrate of the sensor. Tom ********************************************
  #4 (permalink)
Old 04-30-2009, 10:32 PM
Junior Member
Default
Thank you both so much for the suggestions - we're gonna take a look at it this weekend.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Dryer has heat but takes forever to dry rcooks87 Dryer Repair 23 06-28-2009 06:48 AM
Electric Dryer cycles but no heat; cycle runs forever. chele163 Dryer Repair 1 03-30-2009 07:44 PM
Runs forever and No Heat brianosmi Dryer Repair 4 10-25-2008 06:27 PM
rinse runs forever rapidracing Dishwasher Repair 0 08-01-2008 06:58 AM
