Discuss
Whirpool Dryer will not heat up
 in
Dryer Repair
The dryer will not heat, but runs fine. I have replaced the termal cut off and themostate. I have 120
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirpool Dryer will not heat up
  #1 (permalink)
Old 12-06-2007, 04:09 PM
GaryA GaryA is offline
Junior Member
GaryA is on a distinguished road
Default Whirpool Dryer will not heat up
Brand: Whirlpool   Age: More than 10 years
The dryer will not heat, but runs fine. I have replaced the termal cut off and themostate. I have 120 volts to each leg where the dryer cord plugs into. I have continuity on all thermostats, and I have 120 volts, but I don't have 240 at the element. What could be wrong?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 04:21 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Check at the motor to see if there is any burnt wires, look to see if the heavier wires at the motor switch are ok, these wires should be red and orange, if ok it could be the motor switch
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with installing inner glass in Whirpool over door kmg126 Oven Repair (including Ranges and Cooktops) 1 11-20-2007 12:16 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Kenmore/Whirpool detergent cup (lid) problem meyerweb Dishwasher Repair 1 10-12-2007 03:11 AM
whirpool frige water dripping from dispenser chaspitifer Refrigerator & Freezer Repair 1 08-09-2007 05:53 AM
Need clean cloths, whirpool washer smurzynski Washer Repair 1 08-06-2007 05:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
