Discuss
it wont heat
 in
Dryer Repair
dryer wont heat,check all the themostate and thermel cut off and also thermel fuse.it tumble but it did not heat,i
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » it wont heat
  #1 (permalink)
Old 04-28-2009, 08:38 PM
Member
mani is on a distinguished road
Default it wont heat
Model Number: 11063932102   Brand: Kenmore   Age: 5 - 10 years
dryer wont heat,check all the themostate and thermel cut off and also thermel fuse.it tumble but it did not heat,i diagnosed the 110 which come from motor is coming but other 110 is missing which come from some where control system,what could be wrong
Ads By Google
Related Models
Kenmore 1106407400 KENMORE GAS DRYER
Kenmore 1106407401 GAS DRYER
Kenmore 1106407500 KENMORE GAS DRYER
Kenmore 1106407501 KENMORE GAS DRYER
Kenmore 1106407502 KENMORE GAS DRYER
Kenmore 1106407540 KENMORE GAS DRYER
Kenmore 1106407700 KENMORE GAS DRYER
Kenmore 1106407701 KENMORE GAS DRYER
Kenmore 1106407702 KENMORE GAS DRYER
Kenmore 1106407740 KENMORE GAS DRYER
Kenmore 1106407741 KENMORE GAS DRYER-NOVEMBER, 1964
Kenmore 1106407800 KENMORE GAS DRYER
Kenmore 1106407801 KENMORE GAS DRYER
Kenmore 1106407840 KENMORE GAS DRYER
Kenmore 1106407841 KENMORE GAS DRYER
Kenmore 1106407900 KENMORE GAS DRYER
Kenmore 1106407901 KENMORE GAS DRYER
Kenmore 1106407902 KENMORE GAS DRYER
Kenmore 1106407920 KENMORE GAS DRYER
Kenmore 1106407922 KENMORE GAS DRYER
Kenmore 1106407930 KENMORE GAS DRYER
Kenmore 1106407931 KENMORE GAS DRYER
Kenmore 11064082200 ELECTRIC DRYER
Kenmore 11064082201 ELECTRIC DRYER
Kenmore 1106408400 KENMORE ELECTRIC DRYER
Kenmore 1106408401 KENMORE ELECTRIC DRYER
Kenmore 11064084200 ELECTRIC DRYER
Kenmore 11064084201 ELECTRIC DRYER
Kenmore 1106408500 KENMORE ELECTRIC DRYER
Kenmore 1106408501 KENMORE ELECTRIC DRYER
Kenmore 1106408540 KENMORE ELECTRIC DRYER
Kenmore 11064086200 ELECTRIC DRYER
Kenmore 11064086201 ELECTRIC DRYER
Kenmore 1106408700 KENMORE ELECTRIC DRYER
Kenmore 1106408701 KENMORE ELECTRIC DRYER
Kenmore 1106408740 KENMORE ELECTRIC DRYER
Kenmore 1106408741 KENMORE ELECTRIC DRYER
Kenmore 1106408800 KENMORE ELECTRIC DRYER
Kenmore 1106408801 KENMORE ELECTRIC DRYER
Kenmore 1106408840 KENMORE ELECTRIC DRYER
Kenmore 1106408841 KENMORE ELECTRIC DRYER
Kenmore 1106408900 GAS DRYER
Kenmore 1106408901 KENMORE ELECTRIC DRYER
Kenmore 1106408902 KENMORE ELECTRIC DRYER
Kenmore 1106408920 KENMORE ELECTRIC DRYER
Kenmore 1106408922 KENMORE ELECTRIC DRYER
Kenmore 1106408930 KENMORE ELECTRIC DRYER
Kenmore 1106507400 KENMORE GAS DRYER
Kenmore 1106507500 KENMORE GAS DRYER
Kenmore 1106507700 KENMORE GAS DRYER
Kenmore 1106507800 KENMORE GAS DRYER
Kenmore 1106507801 KENMORE GAS DRYER
Kenmore 1106507802 KENMORE GAS DRYER
Kenmore 1106507810 KENMORE GAS DRYER
Kenmore 1106507820 KENMORE GAS DRYER
Kenmore 1106507821 KENMORE GAS DRYER
Kenmore 1106507822 KENMORE GAS DRYER
Kenmore 1106507823 KENMORE GAS DRYER
Kenmore 1106507825 KENMORE GAS DRYER
Kenmore 1106507830 KENMORE GAS DRYER
Kenmore 1106507831 KENMORE GAS DRYER
Kenmore 1106507920 KENMORE GAS DRYER
Kenmore 1106507921 KENMORE GAS DRYER
Kenmore 1106507923 KENMORE GAS DRYER
Kenmore 1106507930 KENMORE GAS DRYER
Kenmore 1106507933 KENMORE GAS DRYER
Kenmore 1106507934 KENMORE GAS DRYER
Kenmore 1106507935 KENMORE GAS DRYER
Kenmore 1106507940 KENMORE GAS DRYER
Kenmore 1106507941 KENMORE GAS DRYER
Kenmore 1106508400 KENMORE ELECTRIC DRYER
Kenmore 1106508500 KENMORE ELECTRIC DRYER
Kenmore 1106508700 KENMORE ELECTRIC DRYER
Kenmore 1106508800 KENMORE ELECTRIC DRYER
Kenmore 1106508801 KENMORE ELECTRIC DRYER
Kenmore 1106508802 KENMORE ELECTRIC DRYER
Kenmore 1106508810 KENMORE ELECTRIC DRYER
Kenmore 1106508811 KENMORE ELECTRIC DRYER
Kenmore 1106508820 KENMORE ELECTRIC DRYER
Kenmore 1106508821 KENMORE ELECTRIC DRYER
Kenmore 1106508822 KENMORE ELECTRIC DRYER
Kenmore 1106508921 KENMORE ELECTRIC DRYER
Kenmore 1106508922 KENMORE ELECTRIC DRYER
Kenmore 1106508923 KENMORE ELECTRIC DRYER
Kenmore 1106508930 KENMORE ELECTRIC DRYER
Kenmore 1106508933 KENMORE ELECTRIC DRYER
Kenmore 1106508934 KENMORE ELECTRIC DRYER
Kenmore 1106508935 KENMORE ELECTRIC DRYER
Kenmore 1106508940 KENMORE ELECTRIC DRYER
Kenmore 1106517400 KENMORE GAS DRYER
Kenmore 1106517401 KENMORE GAS DRYER
Kenmore 1106517402 KENMORE GAS DRYER
Kenmore 1106517500 KENMORE GAS DRYER
Kenmore 1106517501 KENMORE GAS DRYER
Kenmore 1106517502 KENMORE GAS DRYER
Kenmore 1106517510 KENMORE GAS DRYER
Kenmore 1106607400 KENMORE GAS DRYER
Kenmore 1106607401 KENMORE GAS DRYER
Kenmore 1106607410 KENMORE GAS DRYER
Kenmore 1106607500 KENMORE GAS DRYER
Kenmore 1106607501 KENMORE GAS DRYER
Kenmore 1106607600 KENMORE GAS DRYER
Kenmore 1106607601 KENMORE GAS DRYER
Kenmore 1106607700 KENMORE GAS DRYER
Kenmore 1106607701 KENMORE GAS DRYER
Kenmore 1106607710 KENMORE GAS DRYER
Kenmore 1106607711 KENMORE GAS DRYER
Kenmore 1106607800 KENMORE GAS DRYER
Kenmore 1106607801 KENMORE GAS DRYER
Kenmore 1106607802 KENMORE GAS DRYER
Kenmore 1106607810 KENMORE GAS DRYER
Kenmore 1106607900 KENMORE GAS DRYER
Kenmore 1106607910 KENMORE GAS DRYER
Kenmore 1106607911 KENMORE GAS DRYER
Kenmore 1106607920 KENMORE GAS DRYER
Kenmore 1106607921 KENMORE GAS DRYER
Kenmore 1106607930 KENMORE GAS DRYER
Kenmore 1106607931 KENMORE GAS DRYER
Kenmore 1106607940 KENMORE GAS DRYER
Kenmore 1106608400 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 04-29-2009, 04:27 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is the tech sheet
https://www.servicematters.com/docs/...%203980052.pdf
Check that you have the proper power at the plug.
L1 to Neutral and L2 to Neutral should be 120 volts
Also L1 to L2 should be 240 volts.
It is not uncommon to loose half the line without actually tripping the breaker.
Depending on which side drops out the unit will run but not heat.
Flip the breaker off/on slowly a couple times.
Be careful, 240 volts is lethal.
__________________
  #3 (permalink)
Old 04-29-2009, 05:00 AM
Member
Default
thank u for your response,there is no problem with power ,L1 and L2 already giving me 240
  #4 (permalink)
Old 04-29-2009, 05:13 AM
Senior Expert
APP Volunteer
Default
Is the heater itself OK?
Looks like the heater relay and the motor relay are the same.
Check this just to be sure.
If they are the same, swap them
Now if it will not start you know the relay is shot.
__________________
  #5 (permalink)
Old 04-29-2009, 05:17 AM
Member
Default
yes i am thinking aswell this could be the heater relay but not a control board which is beside the relay? thank you for your quick response
  #6 (permalink)
Old 04-29-2009, 06:27 AM
Senior Expert
APP Volunteer
Default
Could be the control board but you want to eliminate everything else before coming to that conclusion as it is the most expensive part.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dry wont Heat hramos Dryer Repair 0 02-16-2010 10:17 PM
wont heat sherifdude Microwave Repair 0 01-21-2010 08:37 AM
Wont heat 18634 Oven Repair (including Ranges and Cooktops) 3 06-23-2009 05:55 PM
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 09:53 AM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
