Discuss
Dryer won't start.
 in
Dryer Repair
My dryer was working fine yesterday, I can't remember if I actually started it this morning, but when I went
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start.
  #1 (permalink)
Old 04-28-2009, 06:54 PM
Junior Member
kayleediane is on a distinguished road
Default Dryer won't start.
Brand: Admiral   Age: 1 - 5 years
My dryer was working fine yesterday, I can't remember if I actually started it this morning, but when I went to switch the laundry over the clothes inside were still wet. When my husband was in the shower this morning he said that the water and the lights very briefly shut off. We checked the breaker and that is fine, the belt fine, the pully is fine. The light is not on, when I first checked it this morning you could hear the timer very faintly and then when I tried it again later there was nothing.
Ads By Google
  #2 (permalink)
Old 04-29-2009, 05:36 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
you need to replace the thermal fuse. the part # is la-1053. if you unplug the dryer, you will need to pop up the top of the dryer. get a putty knife, and slide it under the top on the right side, about 3 inches from the end, and you will hit a clip to release the top, do the same on the other side, and then push the top back and rest it on the back wall. now, up top, in the rear, right in the middle, is the heating element. on the right side of the element housing, about 6 inches down is the thermal fuse. just follow the 2 white wires. the kit will come with the thermostat mounted on top of the heating element. replace it too. but the most inportant thing to do, is to take off the front and clean the blower housing it is all full of lint. just look inside the front, on the right and left side, about 4 inches from the top is a 1/4 inch screw, remove it on each side, and then lean the front towards you, and take the wires off the door switch, and remember where they go, and then lift up on the whole front, and clean the blower housing. clean the vent hose out behind the dryer, and be sure it is clear to the outside. good luck, and let me know how it goes. tom
  #3 (permalink)
Old 04-29-2009, 06:24 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
When you checked the breaker did you just look at it.
If yes, then try turning it off/on slowly a couple times.
It is not uncommon to loose half the line without actually tripping the breaker.
If you have a meter check the voltage at the plug.
Should be 120 volts between L1 and Neutral and between L2 and Neutral.
Also 240 between L1 and L2.
__________________
  #4 (permalink)
Old 04-29-2009, 06:31 AM
Senior Expert
APP Volunteer
Default
La-1053 is the answer. Cut and dry denman!! No need to complicate it!! Tom
  #5 (permalink)
Old 04-29-2009, 06:39 AM
Junior Member
Default
what is LA 1053?
  #6 (permalink)
Old 04-29-2009, 06:43 AM
Junior Member
Default
Never mind figured it out. Thanks.
  #7 (permalink)
Old 04-29-2009, 06:46 AM
Junior Member
Default
We cleaned everything out last night, we will go and get the part today. I will let you know, thanks for your help.
  #8 (permalink)
Old 04-30-2009, 07:02 PM
Junior Member
Default
Okay we did what you said and it is working now, but we only had it on for about 15 seconds and it really stinks and my husband seems to think the back of it was warmer than it should be for that short amount of time. Any ideas what might be causing the smell?
  #9 (permalink)
Old 05-01-2009, 05:13 AM
Senior Expert
APP Volunteer
Default
The back is where the element is. It should be warmer. Turn the dryer on and go outside where the vent is, and make sure the air is coming out good. The smell might be lint on the element. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
dryer start button noise - dryer won't run brhodes58 Dryer Repair 6 03-14-2009 02:11 PM
