| » dyer knob does not move |
Model Number: keyS850gQ0 Brand: Kitchen Aid Age: More than 10 years
The control knob on the dryer has ceased to move through the drying cycle. This happens in both the ‘Timed Dry’ cycle and the ‘Electric Sensor Dry’ cycle. As a result, the dryer does not automatically shut-off during these cycles. When the knob is manually turned to the ‘OFF’ position, the dryer shuts off. The heater does come on and clothes get dried.
Replacement parts for WHIRLPOOL KEYS850GQ0 | AppliancePartsPros.com Best way to check is with a meter. Check to see if the timer motor is getting voltage (120 volts) when it should. If yes and it is not advancing then the timer is shot. If no, you have a problem elsewhere in the machine. Be careful, there is 240 volts in areas of the control panel and it is lethal!!!
__________________
Quote:
kayakcrzy is correct just checking it for resistance can be be confusing.
Timer motor's can short out part of the motor coil so it still has continuity but will not run OR the gears can strip Or the bearings can seize up. That is why I suggested you check for voltage across the motor. If it does not advance when it receives voltage it is shot regardless of the cause.
__________________
Good Job Asshish!!! I sometimes am a little harsh, as a technician running calls all day, I just know what to do, and don't have to whip my meter out, and make all kinds of useless checks. To me it was cut and dry. Glad you got it handled, and thank you for letting us know. Tom ********************************************
| Display Modes | |
| Should Defrost Timer Knob Move? | tomh125 | Refrigerator & Freezer Repair | 1 | 08-25-2009 12:01 PM |
| dryer knob does not move | aashish | Dishwasher Repair | 0 | 04-28-2009 01:27 PM |
| Dryer timer knob does not move | Jendryer | Dryer Repair | 1 | 04-22-2009 02:43 PM |
| dyer won't dry | keith carter | Dryer Repair | 1 | 04-06-2009 09:07 PM |
| dyer | cris francisco | Dryer Repair | 1 | 12-12-2008 12:29 PM |
