Discuss
maytag dryer keeps stopping/turning off
 in
Dryer Repair
maytag dryer keeps stopping/turning off and shows an 'error' code of 6e and for the life of us we
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » maytag dryer keeps stopping/turning off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-06-2007, 02:45 AM
mymoolahsgone mymoolahsgone is offline
Junior Member
mymoolahsgone is on a distinguished road
Question maytag dryer keeps stopping/turning off
Model Number: LSG1000   Brand: Maytag   Age: 5 - 10 years
maytag dryer keeps stopping/turning off and shows an 'error' code of 6e and for the life of us we haven't been able to fix this problem nor have we had any luck in locating the description of this code. thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 03:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
There is two things what could cause such problem.
The first thing is a restricted air flow due to clogged vent. Disconnect the vent hose from the dryer and run a couple loads without the hose. If it would run fine then the vent inside walls has to be cleaned.
If there is nothing wrong with the vent then the problem is a bad thermistor (#10 on the blower housing break down diagram).
- The part number for the thermistor AP276475
- Here are the break down diagrams for the Maytag dryer/washer Model LSG1000
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lower arm not turning Philip Wolke Dishwasher Repair 2 01-27-2008 10:22 AM
Oven not turning on Ronelpaso Oven Repair (including Ranges and Cooktops) 0 12-03-2007 09:49 AM
not turning of the drum scott glynn Washer Repair 1 10-12-2007 10:51 AM
Dryer keeps stopping after 20 minutes dsbell Dryer Repair 1 08-20-2007 11:33 AM
Maytag Dryer: Drum Not Turning miatahowie Dryer Repair 2 07-26-2007 07:18 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
