| » Rattling Noise |
Model Number: 11065922401 Brand: Kenmore Age: 1 - 5 years
Our dryer started to make a horrible screeching rattling noise and my husband decided it had to do with the drum seal and replaced that. Now when we tried to use it, it make a rattling noise, not constant but like more, less, more, less - rhythmic. He sent me online to try to find a schematic or parts diagram, but I can't find anything anywhere. What could be causing the rattle and where can I find a parts diagram? Thanks!
Here is a wiring diagram for you.
https://www.servicematters.com/docs/...%203979710.pdf Here are parts breakdowns http://www.********************************.com/partsdirect/getModel!retrieve.pd;jsessionid=6EpO5Mc9GxZhFDGt+t kRUg**.shcapp3305?modelNumber=11065922401&pop=flus h It will not be the timer. Check that the blades inside the drum are tight. A rattle is often the rear support rollers. Check that the rubber roller itself is OK and that the bearing/shafts are OK. Also check that the drum surface where the rollers ride is clean and that the drum is not cracked. Screeching is often the idler roller, front glides or the motor's bearings. But by the sound of where the noise is coming from (back,rear,bottom) I would put my money on the support rollers.
__________________
| Display Modes | |
| No Heat and Rattling Noise | pak21 | Dryer Repair | 1 | 06-13-2009 04:51 PM |
| Dryer Rattling & Grinding Noise | Avatar3 | Dryer Repair | 1 | 03-12-2009 04:41 AM |
| Rattling noise in Maytag dishwasher | xxxbowl300 | Dryer Repair | 1 | 12-18-2008 12:39 PM |
| Rattling noise near refrigerator controls | mala88 | Refrigerator & Freezer Repair | 0 | 10-30-2008 02:36 PM |
| GE ARTICA rattling noise | Kwing Lee | Refrigerator & Freezer Repair | 2 | 04-25-2008 12:40 AM |
