Discuss
Haunted Dryer?
 in
Dryer Repair
I hope someone can help since this is driving me nuts! Our dryer is 20 yrs old, had been ok,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Haunted Dryer?
  #1 (permalink)
Old 04-25-2009, 09:56 PM
Junior Member
slimjim is on a distinguished road
Default Haunted Dryer?
Model Number: 110.86980100   Brand: Kenmore   Age: More than 10 years
Our dryer is 20 yrs old, had been ok, but in the lsat few yr. noisy, thought the belt had slipped.
Last yr. replaced heat. element. worked fine but then suddenly would run and stop after 20 min.- 1 hr. Top of dryer seemed to get very hot, then realised there was no lint in catcher, so i pulled back off and disovered the lint chute assembly was 100% clogged and i cleaned it!
Other day, nothing happ. when i tried to start it last week, so i puled the belt off and it had some cracks, then i cleaned motor and it started up and ran fine the whole cycle, but then again it would not start for 1 hr. and would only work with lite loads.
But now it seems to shut down every few 10-20 min. when i push the start button, either nothing or goes like DDRRRR and sometimes starts and sometimes not!
I wonder if the cracked belt streched and if an overheat unit keeps shutting it down?
Ads By Google
Related Models
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
  #2 (permalink)
Old 04-26-2009, 05:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like the motor is overheating and is on it's last legs.
It is probably overheating and tripping it's internal thermal cutoff.
Try rotating the drum in the correct direction, should rotate fairly easily.
Just a check to be sure drum is not jammed.
The following may take two people.
Open the door.
Hold the door switch closed.
Push the start switch.
While the unit is making the buzz rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start rotating, the motor is probably had it.
__________________
  #3 (permalink)
Old 05-04-2009, 10:10 PM
Junior Member
Default
Well, i put a new motor and belt in in today! It ran fine for 3 loads about 2 hrs. total, but suddenly the breaker in the main breaker box kicked off, and will not reset. So i will have to get a new Breaker.
I am wondering even though the Motor was new, if maybe it had a problem?
It did have a different centrifugal switch and the wires had to go on different locations, it was somewhat confusing. Is it possible i put a wire on the wrong connection?
Thank you, for any advise.
  #4 (permalink)
Old 05-05-2009, 03:59 AM
Senior Expert
APP Volunteer
Default
I assume that you also tried resetting the breaker with the unit unplugged.
If the unit has a dead short the breaker will not reset.
This is always a possibility but it did run 3 loads.
This is also a possibility, unfortunately I cannot find a wiring diagram on the net so cannot be much help here. If you do not have it check in the control console they like to store the diagrams here.
__________________
  #5 (permalink)
Old 05-05-2009, 11:29 AM
Junior Member
Default
Thanks, here is what happened, after i unplugged the unit i was able to reset the main breaker! Like i had said earlier, on the motor, the centrifugal switch is different and set up so that basically, the wires once plugged in, stick up straight, unlike the old one, where they went in sideways. I was worried that thet were to close to the drum, and that the drum could rub on them and cause a problem, even though i had taped them down, the drum rubbed on a couple and on one rubbed the insulation away, and the exposed wire touched the drum, so it burned in two, i spliced another piece of wire in to it and re-routed the rest!
Thank's denman for all the help, one more question, the 2 hub springs which held the motor in place were almost impossible to get back on, what kind of tool is needed for installing those?
Just so i know for next time, all is well!
  #6 (permalink)
Old 05-05-2009, 11:44 AM
Senior Expert
APP Volunteer
Default
You can usually get them back on with a long shaft flat screw diver.
Clip the clamp on one side, then push down and towards the motor mount on the other end till it clips in. May have to give it a bit of a pop.
Others swear by using vice grips.
I assume all the wiring has lots of clearance now.
If the problem reoccurs you may want to try giving the motor a quarter turn.
This is just a I THINK as I cannot find the parts breakdown for this unit.
PS: Glad you got it up and running
__________________
  #7 (permalink)
Old 05-18-2009, 05:02 PM
Junior Member
Default More Trouble!
My dryer worked for 3 weeks, but last night heard a poof and it stopped, circuit breaker did not flip off, took motor to store and basically they said they could not test it and had hell of a time getting another!
The new one however wont do anything, gets juice but wont do squat!
I even tried to run a 120 volt cord to term. 4 & 5 and nothing, so i guess i got another bad one.
As far as i know this above test, proves it's bad!
Thank You!
James
  #8 (permalink)
Old 05-19-2009, 04:49 AM
Senior Expert
APP Volunteer
Default
Yes I would agree with you.
Could always check it with a meter for continuity.
Sounds like this dryer is messing with you, big time!!!
__________________
  #9 (permalink)
Old 05-29-2009, 08:53 AM
Junior Member
Default
Another new Motor and all is well!
Thank's
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Haunted Amana gas range 917gene Oven Repair (including Ranges and Cooktops) 1 10-15-2009 02:50 PM
