| » Dryer makes a buzzing sound when trying to start? |
Model Number: GLER331AS2 Brand: Frigidaire Age: 1 - 5 years
Help! Dryer not working makes buzzing sound but will not start.
Replacement parts for FRG GLER331AS2 | AppliancePartsPros.com Sounds like the motor is shot. Try rotating the drum in the correct direction, should rotate fairly easily. Just a check to be sure drum is not jammed. The following may take two people. Open the door. Hold the door switch closed. Push the start switch. While the unit is making the buzz rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start rotating, the motor is probably had it.
__________________
| Display Modes | |
| Dryer wont start only buzzing sound for 5 seconnds | Kopchak1 | Dryer Repair | 4 | 01-14-2012 07:20 PM |
| refrigerator makes loud buzzing sound | naplesbuilder | Refrigerator & Freezer Repair | 0 | 12-13-2009 10:33 AM |
| Dryer does not start, makes no sound | Pennell | Dryer Repair | 1 | 11-13-2009 03:45 AM |
| Microwave Makes Buzzing Sound | todpin | Microwave Repair | 1 | 06-19-2009 03:29 PM |
| gas dryer will not work but makes sound when you press the start button | cdhawkinsiii | Dryer Repair | 1 | 01-12-2009 05:43 AM |
