| » Drier drum belt how to start in the back or front??? |
| View Poll Results: How do you put on the drum belt on this white westinghouse??? | |||
| help with the drum belt |
0 | 0% |
| do you start in the back to change drum belt?? |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
Model Number: dg400axw1 Brand: White-Westinghouse Age: More than 10 years
I bought the belt I took of the front lil, panel door on the lower left hand side. I took of the vent door panel on the lower left back side. And I took a peek from the top cover where the control panel is located at. I dont know if to change this belt do I need to start in the front where the door is located. Or do I have to loosen the 4 screws that are in the back.. If I do start in the back Im afraid that those screws hold up the drum.. I need help!!!! I need to dry please help!!!! diagrams or blueprints accepted... |
Using a putty knife push the clip (# 9 on the console break down diagram)on each side on top of the front panel to release the top panel.
Lift the top panel and remove the screw (#12 on the cabinet break down diagram) on each side of the front panel and wires from the door switch, and remove the front panel. Remove the access panel on the back of the dryer (#10 on the cabinet break down diagram) and draw the picture of the belt goes on the motor pulley. Remove the belt from the pulleys. Grab the drum with one hand from the back and another hand from the front, lift it up from the back and pull it toward yourself to release it from the rear bearing and pull it out. - Here are the break down diagrams for the White Westinghouse dryer Model DG400AXW1 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| bad drum felt seal(s) Front and back | glenn1 | Dryer Repair | 1 | 11-26-2007 04:43 PM |
| belt/drum/pully | lilphil | Dryer Repair | 1 | 11-14-2007 02:12 PM |
| GE Front Drum Bearing | cassie31899 | Dryer Repair | 3 | 11-02-2007 12:14 PM |
| Cannot put belt on drum properly | jackd3 | Dryer Repair | 2 | 10-12-2007 08:34 PM |
| cannot put drum belt back on tight | frank | Dryer Repair | 1 | 08-10-2007 09:37 PM |
