Discuss
whirlpool dryer turns on heats for 5 min and and keeps turning but not heating?
 in
Dryer Repair
ok I need help fixing this problem. my dryer turns and heats the problem I am having it that when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer turns on heats for 5 min and and keeps turning but not heating?
  #1 (permalink)
Old 04-24-2009, 05:56 AM
Junior Member
nimster64 is on a distinguished road
Default whirlpool dryer turns on heats for 5 min and and keeps turning but not heating?
Brand: Whirlpool   Age: 1 - 5 years
ok I need help fixing this problem. my dryer turns and heats the problem I am having it that when I start the dryer it works fine but after 5 min it still turns or spins but the heat does not come back on. it is gas. I see the filment glowing red but it seems like the gas is not passing through it. I have to shut it off wait 30 mins and turn it back on and it does it again. what do I have to do. thank you for your help in advance.
oh yea it is a whirlpool imperial series 7 cycle 4 temperatures.
comercial quality super capacity plus.
Ads By Google
  #2 (permalink)
Old 04-25-2009, 07:47 AM
Junior Member
Default
any one? I need to dry my cloth.
  #3 (permalink)
Old 04-26-2009, 05:58 PM
Junior Member
Default anyone? my cloths is piling up LOL
ttt any help will be greatly apreciated.
  #4 (permalink)
Old 04-27-2009, 06:14 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
replace the coils on the gas valve, and you will have it. the secondary coil is not functioning. replace the both, and you will be the hero. tom
  #5 (permalink)
Old 04-27-2009, 06:31 AM
Junior Member
Default
thank you for your reply. now I have a question. where can I get the part and the diagram to where the part goes. also my stoves oven is doing a similar thing where it will turn on and after it reaches the temp it shuts off and won't turn back on so I am guessing it is the same problem?the heating element turns red but the gas does not kick in.
  #6 (permalink)
Old 04-27-2009, 06:48 AM
Junior Member
Default
Quote:
here is the info on the dryer
mod:lgn2000jq0
ser:mk3508428
type:bwsr-nat-1206006-cv22
gas type 120v 60hz 6a
  #7 (permalink)
Old 04-28-2009, 05:07 AM
Senior Expert
APP Volunteer
Default
yes, on the oven you also need an ignitor. it is not strong enough to open the gas valve all the time.
on the dryer- first unplug it. then pull the lint filter out, and remove the two phillips head screws right there. then we need to pop up the top. get a putty knife, and slide it under the top, on the right side, about three inches from the end, and you will hit a clip, that will release the top, on that side. do the same on the other side. then push the top up, and rest it on the back wall. now we need to take the front off. look inside the front up top on the right and left side, about six inches from the top, and there will be a 5/16s screw, holding the front on, on each side. remove them, and lean the front toward you a little, and remove the wires from the door switch. then grab the left side of the front panel, and pull up quick and reasonably hard, and that will release the bottom of the front panel from the cabinet. do the same on the other side, and remove the front.
now, the gas valve is right up front. the 2 coils sit right on the top of the gas valve. there will be a metal bracket the holds it in place. remove the 2 phillip head screws, and remove on coil at at time, and replace it with the new on. try to position the new coil in the same position, as the bracket will only fit flush with the gas valve, when the coils are in the right place. then put the wires back on, and the dryer back on, and you have it. tom
  #8 (permalink)
Old 04-28-2009, 06:36 AM
Junior Member
Default
wow thank you that was very detailed. i ordered the parts from your site i am waiting to receive them and i will post the results. thank you for all your help.i will get the model # for the stove and order the parts i need for that. one project at a time. also will the drum fall off when i take the front off? shoul i some how hold it up with something or should i be fine?
  #9 (permalink)
Old 04-28-2009, 06:55 AM
Senior Expert
APP Volunteer
Default
The drum will come forward some, but not off. Tom
  #10 (permalink)
Old 11-16-2010, 11:51 AM
Junior Member
Default
I have another problem with my dryer. it turns one and spins but the heat wont come on. I replaced the two coils and it worked great but it gave up on me again LOL. what part do you think I may need? please send me an invoice so I can purchace the part. my cloth is piling up again. Thank you for all your great advice and parts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gas dryer heats then stops heating? Need Help! cdpken Dryer Repair 5 09-27-2011 08:13 PM
Dryer runs, turns, heats, but won't dry nanatoabunch Dryer Repair 2 08-11-2009 06:38 PM
dryer turns on but timer not turning and no heat ljv2008 Dryer Repair 8 05-13-2009 08:03 PM
dryer runs AND heats for 10 minutes then stops heating and turning awaywardson Dryer Repair 7 04-24-2009 09:00 AM
Whirlpool Dryer heats, rattles, then stops heating jsthomas75 Dryer Repair 1 03-08-2009 05:15 PM
