Discuss
Amana Dryer front drum glide
 in
Dryer Repair
We are confused on what parts to order when replacing the front drum glide or bearing assembly. Our dismantled dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer front drum glide
  #1 (permalink)
Old 04-23-2009, 09:48 AM
jnr jnr is offline
Junior Member
jnr is on a distinguished road
Default Amana Dryer front drum glide
Model Number: ALG443RAC   Brand: Amana   Age: 5 - 10 years
We are confused on what parts to order when replacing the front drum glide or bearing assembly. Our dismantled dryer has worn brackets (3 sided, attached to the front bulkhead with rivets) and no visable pads on the brackets (did it have some at one time?). We are guessing that we need to order parts AP4010165 (brackets) and AP2403213 (pad), but want this confirmed or other suggestions before ordering. Thanks.
Related Models
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
Amana ALW540RMW Washer - Top Loading
Amana ALW540RMW WASHER-TOP LOADING
Amana ALW680RAC WASHER-TOP LOADING
Amana ALW680RAW WASHER-TOP LOADING
Amana ALW780QAC WASHER-TOP LOADING
Amana ALW780QAW WASHER-TOP LOADING
Amana ALW780QMC Washer - Top Loading
Amana ALW780QMC WASHER-TOP LOADING
Amana ALW780QMW Washer - Top Loading
Amana ALW780QMW WASHER-TOP LOADING
Amana ALW880QAC WASHER-TOP LOADING
Amana ALW880QAC1 WASHER-TOP LOADING
Amana ALW880QAW WASHER-TOP LOADING
Amana ALW880QAW1 WASHER-TOP LOADING
Amana ALW891SAW WASHER-TOP LOADING
Amana ALW895SAC WASHER-TOP LOADING
Amana ALW895SAW WASHER-TOP LOADING
Amana ALW990EAC WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Dryer: Drum stopped spinning schwann Dryer Repair 1 12-20-2009 07:19 AM
Dryer drum glide-Amana gwh33@bellsouth.net Dryer Repair 3 06-21-2009 03:37 PM
replacing front drum bearing on GE dryer Maryanne Daniel Dryer Repair 0 03-10-2009 05:54 AM
Glide Drum / rusting drum erniedoeg Dryer Repair 1 03-04-2009 10:08 AM
mAYTAG GAS DRYER DRUM GLIDE BRACKET REPLACEMENT Steve@Hilo Dryer Repair 1 02-27-2008 12:00 PM
