Discuss
spin
 in
Dryer Repair
i have a electric dryer it start it heats but it does not spin Ads By Google Related Models Admiral
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » spin
  #1 (permalink)
Old 09-25-2011, 10:29 PM
Junior Member
derrick5250 is on a distinguished road
Default spin
Model Number: noade7005ayw   Brand: -brand-   Age: Less than 1 year
Ads By Google
Related Models
Admiral NR460 Ref - Single Door
Admiral NR460A Ref - Single Door
Admiral NR460H Ref - Single Door
Admiral NR530 Ref - Single Door
Admiral NR530A Ref - Single Door
Admiral NR530H Ref - Single Door
Admiral NR580 Ref - Single Door
Admiral NR580A Ref - Single Door
Admiral NR580H Ref - Single Door
Admiral NR640 Ref - Single Door
Admiral NR640A Ref - Single Door
Maytag NS207MA  Ref - Sxs
Maytag NS207MW  Ref - Sxs
Maytag NS207NA Ref - Sxs
Maytag NS207NW Ref - Sxs
Maytag NS207PA Ref - Sxs
Maytag NS207PW Ref - Sxs
Maytag NS208MA  Ref - Sxs
Maytag NS208MW  Ref - Sxs
Maytag NS208NA Ref - Sxs
Maytag NS208NW Ref - Sxs
Admiral NS20F7 Ref - Sxs
Admiral NS20F7A Ref - Sxs
Admiral NS20F7H Ref - Sxs
Admiral NS20F8 Ref - Sxs
Admiral NS20F8A Ref - Sxs
Admiral NS20F8H Ref - Sxs
Admiral NS20H7 Ref - Sxs
Admiral NS20H7A Ref - Sxs
Admiral NS20H7H Ref - Sxs
Admiral NS20H8 Ref - Sxs
Admiral NS20H8A Ref - Sxs
Admiral NS20H8H Ref - Sxs
Admiral NS20JX Ref - Sxs
Admiral NS20JXA Ref - Sxs
Admiral NS20JXH Ref - Sxs
Admiral NS20L7 Ref - Sxs
Admiral NS20L7A Ref - Sxs
Admiral NS20L7H Ref - Sxs
Maytag NS229NA Ref - Sxs
Maytag NS229NW Ref - Sxs
Admiral NS22F8 Ref - Sxs
Admiral NS22F8A Ref - Sxs
Admiral NS22F8H Ref - Sxs
Admiral NS22H7 Ref - Sxs
Admiral NS22H7A Ref - Sxs
Admiral NS22H7H Ref - Sxs
Admiral NS22H8 Ref - Sxs
Admiral NS22H8A Ref - Sxs
Admiral NS22H8C Ref - Sxs
Admiral NS22H8H Ref - Sxs
Admiral NS22HP8 Ref - Sxs
Admiral NS22HP8A Ref - Sxs
Admiral NS22HP8H Ref - Sxs
Admiral NS22L8 Ref - Sxs
Admiral NS22L8A Ref - Sxs
Admiral NS24F8 Ref - Sxs
Admiral NS24F8A Ref - Sxs
Admiral NS24F8H Ref - Sxs
Admiral NS24H8 Ref - Sxs
Admiral NS24H8A Ref - Sxs
Admiral NS24H8H Ref - Sxs
Maytag NT153MA  Ref - Top Mount
Maytag NT153MW  Ref - Top Mount
Maytag NT153NA Ref - Top Mount
Maytag NT153NW Ref - Top Mount
Maytag NT155MA  Ref - Top Mount
Maytag NT155MW  Ref - Top Mount
Maytag NT156MA  Ref - Top Mount
Maytag NT156MW  Ref - Top Mount
Maytag NT156NW Ref - Top Mount
Maytag NT156PW Ref - Top Mount
Admiral NT15A5V Ref - Top Mount
Admiral NT15A5VA Ref - Top Mount
Admiral NT15A5VH Ref - Top Mount
Admiral NT15B43G Ref - Top Mount
Admiral NT15B43GA Ref - Top Mount
Admiral NT15B43GH Ref - Top Mount
Admiral NT15B43GL Ref - Top Mount
Admiral NT15B43GLA Ref - Top Mount
  #2 (permalink)
Old 09-26-2011, 01:24 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any info on the given model number, please check it.
Could be something as simple as a broken belt.
Does the motor make any noise at all?
The reason I ask is that the motor has a centrifugal switch on it that closes close to it's operating speed. It switches in the heating element and ensures there is air flow before the heating coil comes on.
If the motor is not turning the heater should not come on.
If it does there could be a problem with the centrifugal switch mechanism.
Usually though you here the motor buzzing as it tries to start.
Another possibility is a grounded element. Then the element comes on even if the centrifugal switch is open. Also the thermostats cannot regulate the heat so it blows the thermal fuse and that kills power to the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
loud noise on spin cycle,the faster the spin gets the louder the winnig gets Edward Loeb Washer Repair 3 02-02-2011 07:30 AM
Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? mikeal21 Washer Repair 1 03-01-2010 06:21 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
