Discuss
dryer heat cycle is not working properly
 in
Dryer Repair
have replaced coil secondary, coil booster cleaned the dryer with vaccum replaced sensor main burner burnes for 15 min now
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer heat cycle is not working properly
  #1 (permalink)
Old 09-24-2011, 12:42 PM
Junior Member
Cmcast is on a distinguished road
Default dryer heat cycle is not working properly
Brand: Kenmore   Age: 5 - 10 years
have replaced coil secondary, coil booster cleaned the dryer with vaccum replaced sensor main burner burnes for 15 min now that i replaced sensor before it would stay on for 5 min only main burner wil try to ignite a couple of times but doesnot on third attemp it will ignite ignitor has continuity.
  #2 (permalink)
Old 10-05-2011, 07:34 PM
Junior Member
Default dryer heat cycle not working properly
Can I please get someone to help with this dryer problem
  #3 (permalink)
Old 10-14-2011, 07:41 PM
Junior Member
Default
Quote:
I found the problem thanks for not offering any help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer doesn't heat properly kevin.m.elkin@rrd.com Dryer Repair 1 12-13-2010 09:53 AM
Duet Gas Dryer won't heat properly engineer21b Dryer Repair 0 10-24-2010 11:18 AM
Spin Cycle not working properly BrokeinNC Washer Repair 1 10-24-2010 08:28 AM
Dryer does not heat properly Pbeaudette Dryer Repair 1 03-30-2010 10:23 PM
Spin Cycle not working properly gdonwallace Washer Repair 0 01-27-2009 01:24 PM
