Discuss
Dryer runs but doesn't heat
 in
Dryer Repair
My dryer runs but does not heat up to dry clothes in any of the settings. We cleaned out the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs but doesn't heat
  #1 (permalink)
Old 08-02-2007, 07:33 PM
Jane Jane is offline
Junior Member
Jane is on a distinguished road
Unhappy Dryer runs but doesn't heat
Model Number: 41792052101   Brand: Kenmore   Age: 1 - 5 years
My dryer runs but does not heat up to dry clothes in any of the settings. We cleaned out the hose of lint and it still doesn't heat/dry. What could be the problem?
Related Models
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
Kenmore 41799180800 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180810 LAUNDRY CENTER
Kenmore 41799180820 LAUNDRY CENTER
Kenmore 41799185100 LAUNDRY CENTER
Kenmore 41799185110 27" LAUNDRY CENTER
Kenmore 41799185120 LAUNDRY CENTER
Kenmore 41799185800 LAUNDRY CENTER
Kenmore 41799185810 27" LAUNDRY CENTER
Kenmore 41799185820 LAUNDRY CENTER
Kenmore 41799190100 LAUNDRY CENTER
Kenmore 41799190110 27" LAUNDRY CENTER
Kenmore 41799190120 LAUNDRY CENTER
Kenmore 41799190800 LAUNDRY CENTER
Kenmore 41799190810 27" LAUNDRY CENTER
Kenmore 41799190820 LAUNDRY CENTER
  #2 (permalink)
Old 08-02-2007, 11:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Jane
It does not heat or it takes very long time to dry? Is it cold or warm inside the dryer at the end of the cycle? Were the dryer is located and how far from the dryer is the vent outlet?
  #3 (permalink)
Old 08-03-2007, 11:25 AM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
Check your heating element and thermostats. Unplug unit and pull one wire off the element and therostats. Check for continuity. The part with no continunity is bad. Replace and be back in business. You can find the part you need right here at this forum. Best of Luck to you.
  #4 (permalink)
Old 08-04-2007, 08:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi jdman
You are very good but this dryer is a gas, not an electric and it does not have a heating elements.
  #5 (permalink)
Old 08-04-2007, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Jane
I'll be glad to help you with your dryer but I need more information. As soon you'll provide it I'll be able to tell you what's wrong.
  #6 (permalink)
Old 08-05-2007, 06:25 PM
Junior Member
Default
It heats up when there is no wet laundry inside of it. But when I have a load in it it does not seem to heat up and is cold inside at the end of the cycle. It is really close to the vent. Thanks for your help.
Jane
  #7 (permalink)
Old 08-07-2007, 10:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Jane
The problem with your dryer are a bad coils on the gas valve. The part number for the new coils is AP2150379
To get access to the coils you have to remove the front panel.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 7 06-15-2009 12:12 PM
Runs no Heat. hucksplace Dryer Repair 0 08-02-2007 05:03 PM
Dryer runs no heat Wesley Dryer Repair 3 07-28-2007 12:23 AM
dryer heat karen Dryer Repair 0 07-23-2007 01:55 PM
