Discuss
dryer drum belt shredded...
 in
Dryer Repair
Hi, bought the new drum belt and tried to get it on. Tension is way too loose. Not sure which
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer drum belt shredded...
  #1 (permalink)
Old 12-03-2007, 11:33 AM
mrosevear mrosevear is offline
Junior Member
mrosevear is on a distinguished road
Default dryer drum belt shredded...
Model Number: AGY1000AWW   Brand: Admiral   Age: 5 - 10 years
Hi, bought the new drum belt and tried to get it on. Tension is way too loose. Not sure which configuration will tighten it. A quick diagram with path needed under the drum...Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do I remove the metal cabnet and repace a new drum belt Tinas7 Dryer Repair 2 01-03-2008 05:04 PM
dryer drum wally gator Dryer Repair 0 11-22-2007 10:16 AM
belt/drum/pully lilphil Dryer Repair 1 11-14-2007 02:12 PM
Cannot put belt on drum properly jackd3 Dryer Repair 2 10-12-2007 08:34 PM
cannot put drum belt back on tight frank Dryer Repair 1 08-10-2007 09:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
