Discuss
problem long time coming
 in
Dryer Repair
The dryer now shuts off when gets too hot and won't restart until it cools down. Prior to this new
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » problem long time coming
  #1 (permalink)
Old 04-20-2009, 11:06 AM
Junior Member
belinda is on a distinguished road
Default problem long time coming
Model Number: ale643raw   Brand: Amana   Age: 5 - 10 years
The dryer now shuts off when gets too hot and won't restart until it cools down. Prior to this new problem....It had been taking a long time to dry clothes in all settings besides the more dry/less dry setting. Even in this setting the dryer didn't seem to progress and the clothes would be very hot when checked on. It would just run and run.
Wondering if this is something that can be fixed easily.
Related Models
Amana ALE643RAW DRYER- ELE
Amana ALE643RBC DRYER- ELE
Amana ALE643RBW DRYER- ELE
Amana ALE643RCW DRYER- ELE
Amana ALE665SAC DRYER- ELE
Amana ALE665SAW DRYER- ELE
Amana ALE866SAC DRYER- ELE
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
  #2 (permalink)
Old 04-20-2009, 01:48 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your symptons give every indication that the exhaust air flow is impeded somehow. In the moisture driven cycle (more dry/less dry) the moisture cannot escape and that is why the cycle is taking a long time and heating up your clothes. In the timed cycle it takes a long time for the same reason.
You need to open up your machine and clean out all the lint and any other debris, particularly from the blower fan and system. Compressed air is best, if you have it. You need to make absolutely certain that there is nothing impeding the air flow (this is a safety problem too!).
After you have done this, run it again and see if you still have the problems.
Post and let us know how it turns out.
__________________
  #3 (permalink)
Old 04-20-2009, 05:16 PM
Junior Member
Default
Thank you for the help. The problem is half solved now. I cleaned out the inside of the dryer which was packed with lint. The exhaust hose was new as is the outside vent. My clothes dried quickly. The problem came when I put a new load in and the dryer made a funny noise like it was trying to turn on, but it hummed and then stopped as it had been doing. I waited a half hour and it turned on.
  #4 (permalink)
Old 04-20-2009, 05:45 PM
Junior Member
ofblong is on a distinguished road
Default
make sure the blower motor turns freely. It sounds like the Hi-limit switch is shutting it down for over temperature which would mean lack of air flow. If that isnt the problem I dont know what to look at as I just started a thread about what else could cause a similiar problem I am having since all hose's are clean and the blower motor on mine turns freely but the fuse keeps blowing (fuse blows when the Hi limit switch fails to shut down the machine).
  #5 (permalink)
Old 04-21-2009, 03:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for AMANA ALE643RAW | AppliancePartsPros.com
Sounds like your motor has just about had it.
The motor has a start and a main winding. Once it starts rotating the start winding is switched off by one of it's centrifugal switches. If it does not start (the motor will buzz), then the start winding continues to get power and this overheats the motor. It's internal thermal protect opens and you have to wait for the motor to cool down again before trying to restart.
Try turning the drum by hand, it should turn fairly easily.
If it does than the motor probably has to be replaced.
__________________
  #6 (permalink)
Old 04-21-2009, 07:22 AM
Junior Member
Default
Thanks for the help. Just to confirm...I only need a new motor? My husband thinks I'm crazy taking things apart. Is this something easily replaced? Wondering if I should just call a professional.
  #7 (permalink)
Old 04-21-2009, 09:04 AM
Senior Expert
APP Volunteer
Default
Yes to fix this problem, it comes with new switches.
I would not order anything till you get it opened up. You can then check other things like the belt, rear rollers (bearing slop), drum seals, idler wheel, front glides etc. You may as well give it a decent going over and this will give you an idea of the total cost. If it gets up to 30% or so of the cost of a new unit, it may make more sense to scrap it unless it is in very good shape.
Cannot really give an opinion on this. Depends on your mechanical ability.
It is not difficult if you take your time and make yourself drawings etc. so you know where things go when you reassemble it. Also mark the location of any wires you take off. A digital camera can help here.
The hardest part is getting the motor's clips off and then back on.
In any case if you get stuck then you could call a pro.
Another important factor is how determined you are!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
long cycle time fshman54 Dishwasher Repair 0 01-03-2010 07:56 AM
Long Cycle Time phalfmann Dishwasher Repair 0 11-14-2009 08:38 AM
long time to dry rob k Dryer Repair 0 10-06-2009 05:20 PM
Defrosting time is too long. VALENTIN027 Refrigerator & Freezer Repair 5 06-12-2009 01:38 PM
long preheat time david a y Oven Repair (including Ranges and Cooktops) 1 11-06-2008 08:45 AM
