| » Dryer runs but no heat |
Model Number: REL4632DW0 Brand: Roper Age: 5 - 10 years
Do I just nee to replace the heating element? Thanks for any assistance - it's greatly appreciated......
There are two thermostats on the side of the heater-can that go out just as much if not more than the heater. If you have an ohmmeter check the thermostats and the heater. To check these first disconnect power then remove the wires from the two thermostats. Then use your ohmmeter to see if you have continuity between the terminals. If you do the thermostats are good if not they are bad and needs replacing. If you find that one of the thermostats is bad, replace both of them (they come as a kit). If the thermostats are not bad the heater is the most likely problem. But just to be sure the heater should have about 10 ohms. Once the dryer is fixed check the vent and make sure it is clear because this may have caused your problem. Whirlpool Dryer No Heat Repair Guide
| Display Modes | |
| Dryer runs, but no heat | bluky | Dryer Repair | 1 | 12-21-2009 02:36 AM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| dryer runs no heat | Jim Bags | Dryer Repair | 1 | 09-01-2009 05:23 AM |
| Gas dryer runs but won't heat | sblack | Dryer Repair | 1 | 10-07-2008 02:41 AM |
| Dryer runs no heat | glennb | Dryer Repair | 1 | 08-10-2007 10:24 AM |
