| » Kenmore elec dryer |
Model Number: 110.86670100 Brand: Kenmore Age: More than 10 years
Need help for kenmore 11.86670100-6697 please.
Is there a electrical diagram for dryer inside cabinet? Where and how do I get at it? If not-- where can I get electrical diagram online? Major complaint is that dryer drys at same temp no matter what setting of 3 position temp control switch. Got continuity on heating element and visually see no evidence of any shorting. Got continuity on: - thermal cutoff thermostat - 3 position temp control switch ( get 3 differnt ohm readings in 3 positions ) - cycling thermostat - cycling thermostat pre-heater connected to 3 position temp control switch. Trying to check cycling thermostat preheater assemby for correct resistance. PN 61894 What should ohms be for preheater? I would be pleased to get your wisdom on this matter Related Models |
Could not find any info on your unit.
If the wiring diagram is anywhere it will be inside the control console? The cycling thermostat is usually between 5500 to 8500 ohms. If you have only high heat it could be you are running on the Hi Limit Thermostat and the cycling thermostat's contacts are welded closed. Remove it, I usually just heat the face up with a soldering gun to see if it will open. You could also put it on a stove element. Do not know about the wisdom part but hopefully the above will help.
__________________
From omsrof's email:
Denman, Thanks for your prompt reply "The cycling thermostat is usually between 5500 to 8500 ohms. If you have only high heat it could be you are running on the Hi Limit Thermostat and the cycling thermostat's contacts are welded closed. Remove it, I usually just heat the face up with a soldering gun to see if it will open. You could also put it on a stove element." The only parts diagram I have shows 2 of the same adjustable themostats to be used for high limit and low limit-- ( one to be set at 155 deg and one to be set at 135 deg ). On my dryer I have only one cycling thermostat which must serve to cycle between high ( 155?) and low 135?) temps. I have continuity on the single cycling thermostat and I will check the resistance ( which I would think would somehow be different as my cycling thermostat serves voth as high and low). The original question I asked was about the resistance readin for the "cycling thermostat pre-heater" which is a separate divice which fits around my single cycling thermaostat. I have continuity on it and can check what resistance is but I was trying to find out what the correct resistance for the pre-heater was. Part Details - WHIRLPOOL Thermostat, part number: 61894
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
omsrof
I do not work for AppliancePartsPros so emails will not reach me. Just reply on this post. "The cycling thermostat is usually between 5500 to 8500 ohms" I should have called this a cycling thermostat preheater. The only parts diagram I have shows 2 of the same adjustable themostats to be used for high limit and low limit-- ( one to be set at 155 deg and one to be set at 135 deg ). On my dryer I have only one cycling thermostat which must serve to cycle between high ( 155?) and low 135?) temps. I have continuity on the single cycling thermostat and I will check the resistance ( which I would think would somehow be different as my cycling thermostat serves voth as high and low). On a dryer all thermostats (contacts) should be 0 ohms at room temperature. The original question I asked was about the resistance readin for the "cycling thermostat pre-heater" which is a separate divice which fits around my single cycling thermaostat. I have continuity on it and can check what resistance is but I was trying to find out what the correct resistance for the pre-heater was. See above
__________________
| Display Modes | |
| Intermittent heater op on Kenmore elec dryer | soonerdaev | Dryer Repair | 1 | 02-14-2010 02:26 AM |
| kenmore elec dryer | ReCo | Dryer Repair | 0 | 01-22-2010 04:48 PM |
| Kenmore elec dryer motor | timclayton | Dryer Repair | 1 | 10-14-2009 11:33 AM |
| Kenmore elec. dryer troubleshoot | rpack41 | Dryer Repair | 2 | 04-28-2009 05:46 AM |
| Kenmore Elec Dryer | RickP | Dryer Repair | 2 | 04-18-2009 10:04 AM |
