Discuss
maytag electric dryer
 in
Dryer Repair
Timer will not advance in auto dry modes when temp selector is on any heat. Timer will advance in auto
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » maytag electric dryer
  #1 (permalink)
Old 04-16-2009, 04:39 PM
Junior Member
mastertone5 is on a distinguished road
Default maytag electric dryer
Model Number: sde305dayw   Brand: Maytag   Age: 5 - 10 years
Timer will not advance in auto dry modes when temp selector is on any heat. Timer will advance in auto when temp selector is on air fluff. I have changed the cycling thermostat and the the temp selector switch. Any ideas?
Ads By Google
Related Models
Maytag SDE305DAYW Dryer - Ele
Maytag SDE305DAZW Dryer - Ele
Maytag SDE3606AYQ Dryer - Ele
Maytag SDE3606AYW Dryer - Ele
Maytag SDE3606AZW Dryer - Ele
Maytag SDE4000AYW Dryer - Ele
Maytag SDE4000AZW Dryer - Ele
Maytag SDE405DAYW Dryer - Ele
Maytag SDE4606AYW Dryer - Ele
Maytag SDE4606AZW Dryer - Ele
Maytag SDE505DAYQ Dryer - Ele
Maytag SDE505DAYW Dryer - Ele
Maytag SDE505DAZW Dryer - Ele
Maytag SDE515DAYW Dryer - Ele
Maytag SDE515DAZW Dryer - Ele
Maytag SDE5401AYQ Dryer - Ele
Maytag SDE5401AYW Dryer - Ele
Maytag SDE5401AZW Dryer - Ele
Maytag SDE5701AYQ Dryer - Ele
Maytag SDE5701AYW Dryer - Ele
Maytag SDE5701AZW Dryer - Ele
Whirlpool SDF3700W0
Whirlpool SDF3700W2
Whirlpool SDF3700W4
Whirlpool SDF3700W5
Whirlpool SDF3700W6
Whirlpool SDF4000W0
Whirlpool SDF4000W1
Whirlpool SDF4500W0
Whirlpool SDF4500W1
Whirlpool SDF4500W2
Whirlpool SDF4500W3
Whirlpool SDF4500W4
Whirlpool SDF5000W0
Whirlpool SDF5000W1
Whirlpool SDF5000W2
Whirlpool SDF5000W3
Whirlpool SDF5000W4
Whirlpool SDF5000W5
Whirlpool SDF5000W6
Whirlpool SDF6000W0
Whirlpool SDF6000W1
Whirlpool SDF6000W2
Whirlpool SDF6000W3
Whirlpool SDF6000W4
Whirlpool SDF7000W0
Whirlpool SDF7000W1
Whirlpool SDF7800W0
Whirlpool SDF7800W1
Whirlpool SDF7800W2
Whirlpool SDF7800W3
Whirlpool SDF7801W0
Whirlpool SDF8000W0
Whirlpool SDF8000W1
Maytag SDG2606AWW Dryer - Gas
Maytag SDG305DAWW Dryer - Gas
Maytag SDG3606AWQ Dryer - Gas
Maytag SDG3606AWW Dryer - Gas
Maytag SDG4000AWW Dryer - Gas
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
  #2 (permalink)
Old 04-17-2009, 06:58 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAYTAG SDE305DAYW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/maytag...s/16023020.pdf
http://www.servicematters.com/maytag...s/16023139.pdf
In permanent press with heat contacts 3 PK/BU and 4 PK/BK must be closed for the timer to advance when the Cycling Thermostat shuts the heat off.
Unplug the unit. Put it in Perm Press with heat and check that they are closed.
Might also be a broken wire, the orange one from the thermostat to the timer would be at the top of the list.
Always a possibility that the Cycling Thermostat you received is defective. Remove it heat the face up with a soldering gun or on an oven element and check that the Normally Open contacts close when the thermostat trips to off.
The timer would be at the top of the list.
__________________
  #3 (permalink)
Old 04-21-2009, 12:42 PM
Junior Member
peterhicks is on a distinguished road
Default Dryer mde9306aya
steps to change door switch
  #4 (permalink)
Old 04-21-2009, 03:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
This is a duplicated thread.
Answered here: dryer
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
« dryer | Door switch »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Electric Dryer Won't Heat ayersl Dryer Repair 7 02-26-2010 03:09 PM
maytag electric dryer will not start jamesdonald Dryer Repair 1 11-19-2009 02:40 PM
maytag electric dryer won't start shattycat Dryer Repair 1 08-05-2009 05:33 AM
Maytag Electric Dryer mjg1969 Dryer Repair 1 02-05-2009 05:01 AM
maytag Electric dryer gws001 Dryer Repair 17 08-14-2007 05:58 PM
