Discuss
Burner won't fire up
 in
Dryer Repair
While moving 6 years ago we managed to drop the dryer about 6 inches just enough to break the ignitor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burner won't fire up
  #1 (permalink)
Old 12-01-2007, 07:58 PM
warezaholic warezaholic is offline
Junior Member
warezaholic is on a distinguished road
Unhappy Burner won't fire up
Model Number: DG800AXW2   Brand: White-Westinghouse   Age: More than 10 years
While moving 6 years ago we managed to drop the dryer about 6 inches just enough to break the ignitor so I used my old spare dryer ever since and let the Westinghouse sit in a dry corner of the basement for the past six years until the old dryer bit the dust the other day. The dryer had very little use before I stored it away maybe 2 or 3 years.
I went out and bought and installed the new ignitor but now the ignitor works but I'm getting any flame! It was working fine before the move 6 years ago! The gas is hooked up and turned on correctly; everything seems to be running correctly just no flame! What could be wrong?
Joe Barby
warezaholic
joebarby@netzero.com
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-01-2007, 08:04 PM
Junior Member
Default
PS
All the wires were reinstalled correctly (I think) The two wires going to the burner assembly I remembered as a point as "red on right"
  #3 (permalink)
Old 12-02-2007, 05:22 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the gas shut off valve inside the dryer (#12 on the burner break down diagram).
If this is not the issue and the igniter goes on and off, replace the coils on the gas valve.
If the igniter stays on all the time then replace the flame sensor (#24 on the burner break down diagram).
- The part number for the gas valve coil kit AP2150379
- The part number for the flame sensor AP2142636
- Here are the break down diagrams for the White Westinghouse dryer Model DG800AXW2
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Fire Hazard rburgess Refrigerator & Freezer Repair 4 07-14-2008 04:55 PM
Oven Won't Fire OttoZ Oven Repair (including Ranges and Cooktops) 0 11-11-2007 10:07 AM
Fire Hazard? CJRLMPLS Dryer Repair 3 10-10-2007 02:47 AM
burner igniters fire continously Mark65 Oven Repair (including Ranges and Cooktops) 0 10-08-2007 02:51 PM
dryer does not fire Captain Carquest Dryer Repair 1 08-20-2007 10:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
