Discuss
Kenmore Elite Dryer completely dead even after new EC board
 in
Dryer Repair
Last week dryer kept beeping, to make it stop I unplugged, waited a few hours and plugged back in. Panel
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Elite Dryer completely dead even after new EC board
  #1 (permalink)
Old 04-15-2009, 03:59 PM
Junior Member
steviee7 is on a distinguished road
Exclamation Kenmore Elite Dryer completely dead even after new EC board
Model Number: 11061082000   Brand: Kenmore   Age: 5 - 10 years
Last week dryer kept beeping, to make it stop I unplugged, waited a few hours and plugged back in. Panel made the typical beeps and seemed to be fine. Next day went to use it and there was absolutly nothing working. No beeps no LED display
Followed the "for service technicians only" guide that I found inside behind panel. (Thanks Kenmore)
I have voltage coming in, I measured 120V at the electronic control board.(test 1)
Following the troubleshoting guide it points me to the ECboard and Touchpad. (test 5) I can't check the voltage (3v) On contacts P4-1 to P3-1 because I can't get into Diagnostic test mode!
ANyways I check all the buttons on the touchpad and they all make continuity. It says then to replace the ECboard.
I ordered a new ECU for APPros and the same thing happens.
I'm confused now. I'm pretty technically inclined so this I need help.
If I get no response of anything can a themosister or moisture sensor cause it to be completely dead? I would think there would be at least a beep or LEDs on giving me an Error code. Should I replace the Touchpad? even though it seems the ECU?
Help
Ads By Google
Related Models
Kenmore 11061082000 DRYER
Kenmore 1106108400 KENMORE ELECTRIC DRYER
Kenmore 11061084000 DRYER
Kenmore 1106108401 KENMORE ELECTRIC DRYER
Kenmore 1106108500 KENMORE ELECTRIC DRYER
Kenmore 1106108501 KENMORE ELECTRIC DRYER
Kenmore 11061086000 DRYER
Kenmore 1106108700 KENMORE ELECTRIC DRYER
Kenmore 1106108701 KENMORE ELECTRIC DRYER
Kenmore 1106108710 KENMORE ELECTRIC DRYER
Kenmore 1106108800 KENMORE ELECTRIC DRYER
Kenmore 1106108801 KENMORE ELECTRIC DRYER
Kenmore 1106108802 KENMORE ELECTRIC DRYER
Kenmore 1106109100 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109101 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109102 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109105 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 11061092000 DRYER
Kenmore 1106109500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109501 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109504 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109505 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109800 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109801 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109802 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109803 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109804 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109805 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109807 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109808 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109809 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109810 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106110100 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110101 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110102 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110105 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110500 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110501 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110502 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110504 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110505 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110800 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110801 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110802 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110803 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110804 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110805 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110807 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110808 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110809 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110810 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106112600 KENMORE WRINGER WASHER
Kenmore 1106114200 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114210 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114220 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114221 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114222 KENMORE AUTOMATIC WASHER
Kenmore 1106114230 KENMORE AUTOMATIC WASHERS
Kenmore 1106114231 COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114232 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114233 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114234 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114235 KENMORE COIN-OPERATED AUTOMATIC WASHERS (NON-SUDS MODELS)
Kenmore 1106114240 KENMORE AUTOMATIC WASHERS
Kenmore 1106114241 COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114242 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114243 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114244 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114245 KENMORE COIN-OPERATED AUTOMATIC WASHERS (NON-SUDS MODELS)
Kenmore 1106114250 KENMORE AUTOMATIC WASHERS
Kenmore 1106114251 COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114252 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114253 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114254 KENMORE COIN-OPERATED AUTOMATIC WASHERS
Kenmore 1106114255 KENMORE COIN-OPERATED AUTOMATIC WASHERS (NON-SUDS MODELS)
Kenmore 1106114300 KENMORE AUTOMATIC WASHER
Kenmore 1106114350 KENMORE AUTOMATIC WASHER
Kenmore 1106114500 KENMORE AUTOMATIC WASHERS
Kenmore 1106114510 KENMORE AUTOMATIC WASHERS
Kenmore 1106114550 KENMORE AUTOMATIC WASHERS
Kenmore 1106114560 KENMORE AUTOMATIC WASHERS
Kenmore 1106114710 KENMORE AUTOMATIC WASHER
Kenmore 1106114720 KENMORE AUTOMATIC WASHERS
Kenmore 1106114721 KENMORE AUTOMATIC WASHER
Kenmore 1106114722 KENMORE AUTOMATIC WASHER
Kenmore 1106114730 KENMORE AUTOMATIC WASHER
Kenmore 1106114760 KENMORE AUTOMATIC WASHER
Kenmore 1106114770 KENMORE AUTOMATIC WASHERS
Kenmore 1106114771 KENMORE AUTOMATIC WASHER
Kenmore 1106114772 KENMORE AUTOMATIC WASHER
Kenmore 1106114780 KENMORE AUTOMATIC WASHER
Kenmore 1106114800 AUTOMATIC WASHER
Kenmore 1106114801 KENMORE AUTOMATIC WASHER
Kenmore 1106114802 KENMORE AUTOMATIC WASHER
Kenmore 1106114803 KENMORE AUTOMATIC WASHER
Kenmore 1106114810 KENMORE AUTOMATIC WASHER
Kenmore 1106114811 KENMORE AUTOMATIC WASHER
Kenmore 1106114812 KENMORE AUTOMATIC WASHER
Kenmore 1106114813 KENMORE AUTOMATIC WASHER
Kenmore 1106114850 AUTOMATIC WASHER
Kenmore 1106114851 KENMORE AUTOMATIC WASHER
Kenmore 1106114852 KENMORE AUTOMATIC WASHER
Kenmore 1106114853 KENMORE AUTOMATIC WASHER
Kenmore 1106114860 KENMORE AUTOMATIC WASHER
Kenmore 1106114861 KENMORE AUTOMATIC WASHER
Kenmore 1106114862 KENMORE AUTOMATIC WASHER
Kenmore 1106114863 KENMORE AUTOMATIC WASHER
Kenmore 1106115300 KENMORE AUTOMATIC WASHER
Kenmore 1106115350 KENMORE AUTOMATIC WASHER
Kenmore 1106115500 KENMORE AUTOMATIC WASHERS
Kenmore 1106115510 KENMORE AUTOMATIC WASHERS
Kenmore 1106115550 KENMORE AUTOMATIC WASHERS
Kenmore 1106115560 KENMORE AUTOMATIC WASHERS
Kenmore 1106115710 KENMORE AUTOMATIC WASHER
Kenmore 1106115720 KENMORE AUTOMATIC WASHERS
Kenmore 1106115721 KENMORE AUTOMATIC WASHER
Kenmore 1106115722 KENMORE AUTOMATIC WASHER
Kenmore 1106115730 KENMORE AUTOMATIC WASHER
Kenmore 1106115760 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 04-15-2009, 04:46 PM
Junior Member
Question
Great, so I go back out there and test the touchpad function again, and most of the Keys don't work. I swear they did a few days ago when I determined that the ECB was bad. Now I tried again and again and only a few buttons would work. I would still expect a beep or something. Or would it not.
One note. When doing the button test I had my meter on diode test (the manual said to do this) and I would get about 1.2v, well I only saw .6v
So maybe my Panel was the culprit after all,
Any suggestions. I don't suppose I can send back the new ECU in exchange for a Touchpad. ???
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite 665 Motor Dead redgal Dishwasher Repair 3 10-08-2009 05:37 AM
Kenmore Elite Washer Dead Trebbor Washer Repair 3 10-02-2009 06:30 AM
Kenmore Elite Microwave dead Mayfair Microwave Repair 1 06-16-2009 05:10 PM
Kenmore Dishwasher Completely Dead LCharlier Dishwasher Repair 6 05-18-2009 02:09 PM
Kenmore Elite not rinsing completely Joe from PA Dishwasher Repair 7 04-08-2009 08:25 AM
