Discuss
Intermittent dryer heat
 in
Dryer Repair
Have the above mentioned dryer in our RV. It is a 110V. Dryer does not produce heat "all" the time.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Intermittent dryer heat
  #1 (permalink)
Old 04-14-2009, 08:16 AM
Junior Member
edm812 is on a distinguished road
Cool Intermittent dryer heat
Model Number: mah 2400   Brand: GE   Age: 1 - 5 years
Have the above mentioned dryer in our RV. It is a 110V. Dryer does not produce heat "all" the time. While using the same cycle and same load, may have to run 3 cycles. Sometimes, the dryer does not produce any heat for 2 of the cycles and then will be HOT on the 3rd try. Some times the door just gets warm. The exhaust duct has been cleaned and the dryer lint screen is cleaned each load. Thanks in advance for your help. Ed.
Ads By Google
Related Models
Maytag MAH14PDAAL Washer - Horizontal Axis
Maytag MAH14PDAAQ Washer - Horizontal Axis
Maytag MAH14PDAAW Washer - Horizontal Axis
Maytag MAH14PDABL Washer - Horizontal Axis
Maytag MAH14PDABW Washer - Horizontal Axis
Maytag MAH14PDAEW Washer - Horizontal Axis
Maytag MAH14PDAGW Washer - Horizontal Axis
Maytag MAH14PDBAW Washer - Horizontal Axis
Maytag MAH14PDBEW Washer - Horizontal Axis
Maytag MAH14PDBGW Washer - Horizontal Axis
Maytag MAH14PDCBQ Washer - Horizontal Axis
Maytag MAH14PDCBW Washer - Horizontal Axis
Maytag MAH14PDDWW Washer - Horizontal Axis
Maytag MAH14PDSAW Washer - Horizontal Axis
Maytag MAH14PNAEW Washer - Horizontal Axis
Maytag MAH14PNAGW Washer - Horizontal Axis
Maytag MAH14PNAWW Washer - Horizontal Axis
Maytag MAH14PNBAW Washer - Horizontal Axis
Maytag MAH14PNBEW Washer - Horizontal Axis
Maytag MAH14PNBGW Washer - Horizontal Axis
Maytag MAH14PNSAW Washer - Horizontal Axis
Maytag MAH14PRAWW Washer - Horizontal Axis
Maytag MAH14PSAAW Washer - Horizontal Axis
Maytag MAH14PSAGW Washer - Horizontal Axis
Maytag MAH20PDA3W Washer - Horizontal Axis
Maytag MAH20PDAWQ Washer - Horizontal Axis
Maytag MAH20PDAWW Washer - Horizontal Axis
Maytag MAH20PDCXQ Washer - Horizontal Axis
Maytag MAH20PDCXW Washer - Horizontal Axis
Maytag MAH20PNAWW Washer - Horizontal Axis
Maytag MAH20PRAWW Washer - Horizontal Axis
Maytag MAH20PRDWW Washer - Horizontal Axis
Maytag MAH20PSAWW Washer - Horizontal Axis
Maytag MAH21PDA3W Washer - Horizontal Axis
Maytag MAH21PDAGW Washer - Horizontal Axis
Maytag MAH21PDAWQ Washer - Horizontal Axis
Maytag MAH21PDAWW Washer - Horizontal Axis
Maytag MAH21PDCXQ Washer - Horizontal Axis
Maytag MAH21PDCXW Washer - Horizontal Axis
Maytag MAH21PDD3W Washer - Horizontal Axis
Maytag MAH21PDDGW Washer - Horizontal Axis
Maytag MAH21PDDWQ Washer - Horizontal Axis
Maytag MAH21PDDWW Washer - Horizontal Axis
Maytag MAH21PDDXW Washer - Horizontal Axis
Maytag MAH21PNAGW Washer - Horizontal Axis
Maytag MAH21PNAWW Washer - Horizontal Axis
Maytag MAH21PNDGW Washer - Horizontal Axis
Maytag MAH21PNDWW Washer - Horizontal Axis
Maytag MAH21PRAWQ Washer - Horizontal Axis
Maytag MAH21PRAWW Washer - Horizontal Axis
Maytag MAH21PRDWW Washer - Horizontal Axis
Maytag MAH21PSAWW Washer - Horizontal Axis
Maytag MAH21PSDWW Washer - Horizontal Axis
Maytag MAH2400AWW Washer - Horizontal Axis
Maytag MAH2440AGW Washer - Horizontal Axis
Maytag MAH2440BGW Washer - Horizontal Axis
Maytag MAH3000AAW Washer - Horizontal Axis
Maytag MAH3000AEW Washer - Horizontal Axis
International MAH3000AGW Washer - Horizontal Axis
International MAH3000AKW Washer - Horizontal Axis
Maytag MAH3000AWA Washer - Horizontal Axis
Maytag MAH3000AWQ Washer - Horizontal Axis
Maytag MAH3000AWW Washer - Horizontal Axis
International MAH3000BGW Washer - Horizontal Axis
Maytag MAH4000AWQ Washer - Horizontal Axis
Maytag MAH4000AWW Washer - Horizontal Axis
Maytag MAH4000BWQ Washer - Horizontal Axis
Maytag MAH4000BWW Washer - Horizontal Axis
Maytag MAH5500AWQ Washer - Horizontal Axis
Maytag MAH5500AWW Washer - Horizontal Axis
Maytag MAH5500BWQ Washer - Horizontal Axis
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
  #2 (permalink)
Old 04-14-2009, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted is for a washer. Verify and repost it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-14-2009, 04:46 PM
Junior Member
Default
This is to revise my earlier post. The correct model number for the GE dryer is DSKP333EC. Thanks again. Ed.
  #4 (permalink)
Old 04-14-2009, 09:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ed,
I would recommend to take the dryer apart, clean the air ducts and the blower housing and check the heating element. Make sure the blower wheel is not slipping.
Here are the breakdown diagrams and Replacement parts for GE DSKP333EC0WH | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 04-15-2009, 06:08 AM
Junior Member
Default
Thanks Gene for your help!! Will checking for concentricity reveal the working condition of the element? Thanks again Ed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer intermittent heat rpuglia Dryer Repair 3 09-30-2009 01:33 PM
GE Harmony Gas Dryer Intermittent Heat dbyro Dryer Repair 0 09-29-2009 07:00 AM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
Kenmore dryer has intermittent heat acillatem Dryer Repair 5 12-22-2008 05:55 PM
Gas Dryer intermittent heat, Gas smell mikmica Dryer Repair 8 11-29-2007 05:32 PM
