Discuss
timer gets stuck on less dry in auto cycle
 in
Dryer Repair
The dryer was running forever but with heat. So i replaced the cycling thermostat, that did not work so then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » timer gets stuck on less dry in auto cycle
  #1 (permalink)
Old 04-13-2009, 06:44 PM
longneck longneck is offline
Junior Member
longneck is on a distinguished road
Default timer gets stuck on less dry in auto cycle
Model Number: rgx5634kq2   Brand: Roper   Age: 1 - 5 years
The dryer was running forever but with heat. So i replaced the cycling thermostat, that did not work so then all service stores and forums said to replace the Timer. I did and now it still does not advance on the Auto sense dry setting............sometimes it works when starting on very dry but then will get stuck on *Less dry........and still produce heat but runs forever......please help.
Related Models
Whirlpool RGX5634KQ2
Whirlpool RGX5634KQ3 29" Gas Dryer
Whirlpool RGX5634PQ0 29" Gas Dryer
Whirlpool RGX5635EN0
Whirlpool RGX5635EN1
Whirlpool RGX5635EN2
Whirlpool RGX5635EN3
Whirlpool RGX5635EQ0
Whirlpool RGX5635EQ1
Whirlpool RGX5635EQ2
Whirlpool RGX5635EQ3
Whirlpool RGX5635EW0
Whirlpool RGX5635EW1
Whirlpool RGX5635EW2
Whirlpool RGX5635EW3
Whirlpool RGX5636AL0
Whirlpool RGX5636AL1
Whirlpool RGX5636AL2
Whirlpool RGX5636AW0
Whirlpool RGX5636AW1
Whirlpool RGX5636AW2
Whirlpool RGX6634PQ0 29" Gas Dryer
Whirlpool RGX6634RQ0 29" Gas Dryer
Whirlpool RGX6634RQ1 29" Gas Dryer
Whirlpool RGX6646AL0
Whirlpool RGX6646AL1
Whirlpool RGX6646AL2
Whirlpool RGX6646AL3
Whirlpool RGX6646AQ2
Whirlpool RGX6646AQ3
Whirlpool RGX6646AW0
Whirlpool RGX6646AW1
Whirlpool RGX6646AW2
Whirlpool RGX6646AW3
Whirlpool RH0500RAW00
Whirlpool RH0500RDW00
Whirlpool RH0500REW00
Whirlpool RH0500REW01
Whirlpool RH0500REW02
Whirlpool RH0500RWW00
Whirlpool RH0588RBW00
Whirlpool RH0588REW00
Whirlpool RH0588REW01
Whirlpool RH0588REW02
Whirlpool RH0599RBW00
Whirlpool RH0599REW00
Whirlpool RH0599REW01
Whirlpool RH0599REW02
Whirlpool RH0799RBW00
Whirlpool RH0799REW00
Whirlpool RH0799REW01
Whirlpool RH0799REW06
Jenn-Air RH100 Hood
Whirlpool RH1000RAW00
Whirlpool RH1000RDW00
Whirlpool RH1000REW00
Whirlpool RH1000REW01
Whirlpool RH1000REW05
Whirlpool RH1000REW06
Whirlpool RH1000RYW00
Jenn-Air RH100B Hood
Jenn-Air RH100L Hood
Jenn-Air RH100S Hood
Jenn-Air RH100W Hood
Jenn-Air RH101 Hood
Jenn-Air RH101B Hood
Jenn-Air RH101L Hood
Jenn-Air RH101S Hood
Jenn-Air RH101W Hood
Whirlpool RH1099RBW00
Whirlpool RH1099REW00
Whirlpool RH1099REW06
Whirlpool RH1200RWW00
Whirlpool RH1200RXW00
Whirlpool RH123
Whirlpool RH123A1
Whirlpool RH123A2
Jenn-Air RH130 Hood
Jenn-Air RH130B Hood
Jenn-Air RH130L Hood
Jenn-Air RH130S Hood
Jenn-Air RH130W Hood
Whirlpool RH1500RAW00
Whirlpool RH1500RDW00
Whirlpool RH1500REW00
Whirlpool RH1500REW01
Whirlpool RH1500REW02
Whirlpool RH1500REW03
Whirlpool RH1500REW04
Whirlpool RH1500REW05
Whirlpool RH1500REW06
Whirlpool RH1500RWW00
Whirlpool RH1500RXW00
Whirlpool RH1599RBW00
Whirlpool RH1599REW00
Whirlpool RH1599REW03
Whirlpool RH1599REW04
Whirlpool RH1599REW06
Jenn-Air RH170 Hood
Jenn-Air RH170B Hood
Jenn-Air RH170L Hood
Jenn-Air RH170S Hood
Jenn-Air RH170W Hood
Jenn-Air RH180 Hood
Jenn-Air RH180B Hood
Jenn-Air RH180L Hood
Jenn-Air RH180S Hood
Jenn-Air RH180W Hood
Whirlpool RH183
Jenn-Air RH186 Hood
Jenn-Air RH186B Hood
Jenn-Air RH186W Hood
Jenn-Air RH200 Hood
Jenn-Air RH200B Hood
Jenn-Air RH200L Hood
Jenn-Air RH200S Hood
Jenn-Air RH200W Hood
Whirlpool RH2024XLW0
Whirlpool RH2024XLW1
Whirlpool RH2030WXN0
  #2 (permalink)
Old 04-14-2009, 05:03 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
The auto sense drying mode is notoriously filled with problems. My opinion is that it is more of a marketing gimmick then a true contributing part of the machine.
Does it operate normally in the Time Mode?
__________________
  #3 (permalink)
Old 04-14-2009, 05:32 PM
Junior Member
Default
No it does not.......what i have noticed throught the peep hole on front of dryer is that igniter glows orange....then blue flame turns on.... but this is not consistent. intermittently flame goes out and igniter only lights orange....no flame....this is even on high heat.........could it be the solenoid coils(2 and 3wires) ? also how does one get to and check these coils?
  #4 (permalink)
Old 04-14-2009, 05:33 PM
Junior Member
Default
it is almost more of a problem on any high heat setting.
  #5 (permalink)
Old 04-14-2009, 06:16 PM
Senior Expert
APP Volunteer
Default
Hi Longneck
When you get into the gas mechanics you are entering an area that is beyond my area of comfort, so I am going to use this post to ask some of the other techs on this site to respond to you.
Good luck
__________________
  #6 (permalink)
Old 04-14-2009, 07:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
There are two things which I would take care of.
1. Replace the gas valve coils (## 13 & 14 on the diagram)
2. Make sure the vent line is clean all the way to the outlet and the air ducts and the blower housing inside the dryer are clean.
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RGX5634KQ2 | AppliancePartsPros.com
__________________
  #7 (permalink)
Old 04-19-2009, 10:19 PM
Junior Member
Default mystery solved.....
it worked...I changed the Solenoid coil pack and now dryer is working like it did before.
Parts guy said expect about 5-6 years out of new packs i just bought.
  #8 (permalink)
Old 04-19-2009, 10:25 PM
Junior Member
Default How To
Is easy to get two but need help to hold lid.
Take a pry bar or small screwdriver. Pry top lid from the front panel.
there is a snap/clip on front left and right (not visible.)
when you pick up top lid have someone hold it up while you loosen 2 screws from inside by drum, one on each side.
MAKE SURE to UNCLIP latch connector on rt side......while someone is still hloding top pull front cover from its top towards you and lift up.
The coil pack is in bottom left corner......prop or hold drum in upright position and a stubby phillips works fine.
  #9 (permalink)
Old 04-19-2009, 10:26 PM
Junior Member
Default
unplug before any of the above
  #10 (permalink)
Old 04-20-2009, 07:10 PM
arnie460 arnie460 is offline
Junior Member
arnie460 is on a distinguished road
Default
Dirty vent, vent to long, vent kinked, plastic flex vent, etc.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stuck on very dry / less dry in Auto Mode wantofix Dryer Repair 0 02-09-2010 09:56 PM
Timer stuck on AUTO g-in-hove Oven Repair (including Ranges and Cooktops) 1 01-03-2010 05:49 AM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Timer will not advance in Auto Dry KSherer Dryer Repair 1 06-03-2009 01:54 AM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 07:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
