i have a WHIRLPOOL CEM2940TQ1 COMMERCIAL ELECTRIC DRYER that went through our last flood. i dried all parts, sprayed electronics with PB rust inhibitor. dryer runs but heater element wont heat,
ohm out the following parts all test good: heater element high limit cycling thermostat thermal cut off
looks like 2 control (purple wires) run to another switch or sensor on the motor, that i did not test. anything else i can do? thank you, mike
