Discuss
Amana Dryer dries slowly, and More/Less Dry Timer does not advance
 in
Dryer Repair
I have a 3-cycle timer on my Amana Dryer. The timed dry heats up, but takes more than 90 minutes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer dries slowly, and More/Less Dry Timer does not advance
  #1 (permalink)
Old 04-13-2009, 08:24 AM
Junior Member
dtshenoy is on a distinguished road
Default Amana Dryer dries slowly, and More/Less Dry Timer does not advance
Model Number: ALE230RAW   Brand: Amana   Age: 1 - 5 years
I have a 3-cycle timer on my Amana Dryer. The timed dry heats up, but takes more than 90 minutes to dry (I have to do 2 cycles of 45 mins each since the max is 70 mins). The More/Less Dry timer cycle does not advance, but clothes do get dried if I leave it at the More Dry setting and remember to take it out when done.
Related Models
Amana ALE230RAW DRYER- ELE
Amana ALE230RCW DRYER- ELE
Amana ALE331RAC DRYER- ELE
Amana ALE331RAW DRYER- ELE
Amana ALE331RCW DRYER- ELE
Amana ALE443RAC DRYER- ELE
Amana ALE443RAW DRYER- ELE
Amana ALE443RCW DRYER- ELE
Amana ALE565SAC DRYER- ELE
Amana ALE565SAW DRYER- ELE
Amana ALE643RAC DRYER- ELE
Amana ALE643RAW DRYER- ELE
Amana ALE643RBC DRYER- ELE
Amana ALE643RBW DRYER- ELE
Amana ALE643RCW DRYER- ELE
Amana ALE665SAC DRYER- ELE
Amana ALE665SAW DRYER- ELE
Amana ALE866SAC DRYER- ELE
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
  #2 (permalink)
Old 04-13-2009, 08:36 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If you are certain you are getting the appropriate amount of heat, that the drum is turning and that the exhaust fan is blowing,
Then you should open up the dryer cabinet and exhaust cover and clean out absolutely everything, paying particular attention to the air exhaust system. A vac and an air compressor spray are best, but work with what you have. (If you have not done this you are going to be amazed at what is in there!)
After you do this, try a load, and post back the results.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Timer wont advance?? jaredegley Dryer Repair 3 03-12-2009 04:30 PM
Gas dryer timer won't advance irhoghead Dryer Repair 2 03-09-2009 03:55 PM
Whirlpool dryer barely warm, dries too slowly. DoninHouston Dryer Repair 2 02-07-2009 04:32 AM
Dryer Timer Will Not Advance cyclone Dryer Repair 2 01-16-2009 03:10 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 04:22 PM
