estate by whirlpool electric dryer " EED4400SQ0" will not start. door switch, pwr coming, no fuse blown, start switch...all r fine. what else could be the problem. unplug wires to start switch white on rt blk on left... confused about blue wires to the timer and buzzer wires
Originally Posted by: divaconstruction estate by whirlpool electric dryer " EED4400SQ0" will not start. door switch, pwr coming, no fuse blown, start switch...all r fine. what else could be the problem. unplug wires to start switch white on rt blk on left... confused about blue wires to the timer and buzzer wires Diva, Did you check the circuit for the thermal fuse on the blower housing, it should be a closed circuit at all times, if it opened, you won't have power to the motor. The start switch circuit is a "momentary" circuit, It is an open circuit, and closes, when the start button is pressed in, or held and opens as soon as you release the button. It's probably not the issue. The blue wire at the timer and buzzer becomes a neutral circuit when the timer reaches the off increment in the cycle, when the motor stops rotating, the circuit opens, this allows the momentary buzzer to sound at the end of the cycle. We hope this was helpful, :) :) :)
