Discuss
Whirlpool Senseon No heat
 in
Dryer Repair
Ok where I am at... I have power going to the heating coils from the centrifuge switch 120v but no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Senseon No heat
  #1 (permalink)
Old 09-08-2011, 11:46 AM
Junior Member
girwin1123 is on a distinguished road
Default Whirlpool Senseon No heat
Brand: Whirlpool   Age: 5 - 10 years
Ok where I am at... I have power going to the heating coils from the centrifuge switch 120v but no power coming from the heater relay on the control board. There are no error codes being read on the display. So I am totally lost except that maybe the the heater relay is bad? Need help anyone
  #2 (permalink)
Old 09-09-2011, 05:32 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Not sure how you determined that the power on the centrifugal switch side is OK. Using Neutral to troubleshoot heating problems can be confusing because you cannot tell if you are seeing L1 or L2 unless the circuit has been disconnected at the correct point.
If the unit uses a motor and a heater relay try swapping them.
If now it does not start the relay is toast.
Be sure to check the numbers on the relays to be sure they are the same.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Senseon gives E1 error code toneal Dryer Repair 25 07-27-2012 11:00 AM
Whirlpool Senseon Dryer error code PF Tryad Dryer Repair 6 11-03-2011 02:54 PM
Whirlpool Senseon Dryer radrogerdad Dryer Repair 0 09-07-2011 06:52 PM
Whirlpool Senseon Elec. Dryer-digital radrogerdad Dryer Repair 0 09-06-2011 06:57 AM
whirlpool senseon dryer abnormal isunshine Dryer Repair 0 01-26-2008 07:51 PM
