Discuss
No Heat 3 Loads After Element Replacement
 in
Dryer Repair
Dryer was only warm and took 2 to 3 cycles to dry. Replaced the heating element and it worked great
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat 3 Loads After Element Replacement
  #1 (permalink)
Old 11-28-2007, 10:18 PM
jtagscott jtagscott is offline
Junior Member
jtagscott is on a distinguished road
Default No Heat 3 Loads After Element Replacement
Model Number: 96272100   Brand: Sears   Age: More than 10 years
Replaced the heating element and it worked great for 3 loads then that completely quit heating. Everything else seems to work fine.
Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-28-2007, 10:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a clogged vent inside walls which caused the moister to stay inside the dryer and overheat to the dryer.
If it's not heating at all, probably the thermal cut off on the heater box is blown.
- The part number for the thermal cut off kit AP3094224
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-28-2007, 11:16 PM
Junior Member
Default
Thanks so much. I seen those parts back there but wasn't sure what they were. That sounds like that's the fix.
Thanks again.
Jim
  #4 (permalink)
Old 12-11-2007, 02:18 PM
Junior Member
Default Still no heat
I ordered and replaced the thermal cut off kit, but still no heat.
You also were right about the clog inside. I cleaned that out as well.
Is there a way to check if the cut offs are still good? Or is there any other fuse or shut off it could be?
  #5 (permalink)
Old 12-11-2007, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would recommend to perform the troubleshooting according to the heat circuit from the wiring diagram and the break down diagrams for your dryer.
If the thermal cut off is blown - it should be open.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bottem element replacement troubled Oven Repair (including Ranges and Cooktops) 1 11-09-2007 07:37 PM
Heating Element Replacement for Dryer LFriedman Dryer Repair 0 11-06-2007 01:37 PM
Frigidaire Electric Range Heating Element Replacement johnhmon Oven Repair (including Ranges and Cooktops) 0 10-06-2007 05:14 PM
DIY Element Replacement? Lindy513 Oven Repair (including Ranges and Cooktops) 1 09-14-2007 04:08 AM
spin dry only on light loads gwc36@verizon.net Washer Repair 1 07-27-2007 05:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
