| » No Heat 3 Loads After Element Replacement |
Model Number: 96272100 Brand: Sears Age: More than 10 years
Dryer was only warm and took 2 to 3 cycles to dry.
Replaced the heating element and it worked great for 3 loads then that completely quit heating. Everything else seems to work fine. Any suggestions? |
Most likely the problem is a clogged vent inside walls which caused the moister to stay inside the dryer and overheat to the dryer.
If it's not heating at all, probably the thermal cut off on the heater box is blown. - The part number for the thermal cut off kit AP3094224 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
I ordered and replaced the thermal cut off kit, but still no heat.
You also were right about the clog inside. I cleaned that out as well. Is there a way to check if the cut offs are still good? Or is there any other fuse or shut off it could be? |
I would recommend to perform the troubleshooting according to the heat circuit from the wiring diagram and the break down diagrams for your dryer.
If the thermal cut off is blown - it should be open. Gene.
__________________
| Display Modes | |
| Bottem element replacement | troubled | Oven Repair (including Ranges and Cooktops) | 1 | 11-09-2007 07:37 PM |
| Heating Element Replacement for Dryer | LFriedman | Dryer Repair | 0 | 11-06-2007 01:37 PM |
| Frigidaire Electric Range Heating Element Replacement | johnhmon | Oven Repair (including Ranges and Cooktops) | 0 | 10-06-2007 05:14 PM |
| DIY Element Replacement? | Lindy513 | Oven Repair (including Ranges and Cooktops) | 1 | 09-14-2007 04:08 AM |
| spin dry only on light loads | gwc36@verizon.net | Washer Repair | 1 | 07-27-2007 05:36 PM |
