| » Maytag Gas Dryer |
Model Number: LDG590 Brand: Maytag Age: More than 10 years
I just replaced broken gas valve coils on this dryer...It now will ignite, however the flame only stays lit for about five seconds before going out...This process repeats itself roughly every 30-45 seconds with the same result...This causes the dryer to not be as hot as it should be...I saw on another site that this problem may be caused by an air flow problem and i believe that the duct connected to the dryer is of the flexible foil type which isn't the best type...For years we had the plastic duct connected to it and I see lint has accumulated inside the dryer...Are there any other possible causes of this problem...I will soon try to clean any lint that may have accumulated in the dryer/duct system...Please advise me ASAP.
Thanks, JDHamm82 Ads By Google Related Models |
Take the dryer apart and clean the air dusts inside and the blower housing. Make sure the blower wheel is not broken or worn out. Disconnect the vent hose from the dryer and run it without this hose. Post the results.
Here are the break down diagrams and Replacement parts for MAYTAG LDG590 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks for your help!!! |
Quote:
If there are no any restrictions found then possible the high limit thermostat has gone bad. Gene. A vacuum is good.
__________________
You are welcome. I'm glad you were able to fix it.
__________________
The dryer now make a loud whirring noise when running...a repairman told my mom about a wheel that needs replacing...is this the blower wheel or something different?...PLease advise ASAP.
Thank You! Jason H. |
Jason,
Besides the blower wheel there are two drum support rollers and the idler pulley in this dryer. All of them can cause an excessive noise. Gene.
__________________
The best way to save money is to take the dryer apart, inspect all parts and order the parts which are worn out. Nobody can tell you exactly what has to be replaced without seeing it.
__________________
| Display Modes | |
| Maytag Gas Dryer | lxk8 | Dryer Repair | 3 | 07-22-2010 12:06 PM |
| maytag gas dryer will run then won't | kennew | Dryer Repair | 3 | 10-16-2009 05:03 PM |
| Maytag Gas Dryer | Steve Barbara | Dryer Repair | 0 | 08-27-2009 01:52 PM |
| Maytag gas dryer | essy9 | Dryer Repair | 0 | 06-29-2009 01:05 PM |
| Maytag gas Dryer | Dwasko | Dryer Repair | 0 | 06-08-2009 03:15 PM |
