Discuss
starts up but will stay running
 in
Dryer Repair
i have two prolem. when you push the start button the unit turn on, when you release the button the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » starts up but will stay running
  #1 (permalink)
Old 11-28-2007, 05:45 PM
mtmeek mtmeek is offline
Junior Member
mtmeek is on a distinguished road
Talking starts up but will stay running
Model Number: 110.63932102   Brand: Kenmore   Age: 1 - 5 years
i have two prolem. when you push the start button the unit turn on, when you release the button the unit stops.
2) then the unit was working the heater would not heat up.
i have checks all wiring and fuse on the heater unit. i bypassed the heater relay and the unit will heat up.
the first problem where it will not stay on started after i tried checking the voltage at the heater relay.
thank you for your help
mike meek
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-28-2007, 10:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad control board. It should sense when the dryer starts.
- The part number for the control board AP3598457
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't stay powered on karlkauai Dryer Repair 2 12-09-2007 04:49 PM
Oven won't stay lit donnalee115 Oven Repair (including Ranges and Cooktops) 3 11-27-2007 04:27 PM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 09:23 PM
Maytag dryer won't stay running Schoolmom3 Dryer Repair 1 08-12-2007 02:59 AM
2nd post - Dryer won't stay running Schoolmom3 Dryer Repair 0 08-11-2007 11:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
