I have a maytag dryer that I cant seem to tension the belt.. The belt arm in its normal resting position leaves a few inches of slack. That is the first picture. In the second picture I pushed the belt arm further to the right so it hooked the motor bracket. I thought maybe this was the right place for it.. but in this case the belt is too short. any ideas what I am doing wrong? personalt attached the following image(s):
